help connecting to ISY994i
I thought I had my problem solved connecting with my Macbook Pro by using Firefox.  But this evening I am getting an error when trying to connect.  The admin window comes up but 2 errors pop up and no login window.  First error is an XML Parse Error http://(location number here)/desc.  Under that is another window error with Socket Open Failed java.net.SocketTimeoutException.  What in the world are these?  I was able to connect just 5 hours ago.  Ugh!
First ensure that you have the latest version of Java installed. Clear the cache. Try again.
If that doesn't solve the problem, then open the Java Control panel and select the Security tab > Edit Site List and enter the IP address of you ISY including any port you may have assigned. Any success?
Restarted my computer before seeing this and am up and running again.  Thanks!
That's a lot easier than having to do something B)
