ISY994i errors during restore of backup
I recently had to restore backup to ISY994i IR/Pro after doing a hard reset. I noticed that restore generated couple of errors, I forgot to note them down. Is it normal to see errors during restore? Version 4.2.30.
Arun
If you have any battery operated devices they need to be put into linking mode, one device at a time, then do a restore device. Battery operated devices sleep until put into the linking mode in order to save battery life.
Take a look at your devices to see if you have any 1101 next to the device name which indicates that it needs to be written to.
Edited by Techman
There are no battery operated devices. I only have 2477 and 2466 type switches. No devices have 1101 against them.
Arun
If they're are no ! or no 1101 to the left off the device names in your device tree then you're probably OK.
You can always run a link table diagnostics and then a compare for a device if you think you may have an issue with a particular device. If errors show up then do a restore device to correct them.
I've also had error messages come and go when doing a restore but all seemed to be OK.
