October 22, 201510 yr I'm just curious if I'm missing something. I got iBeacons in every room my only issue is mobilinc has no ability to set distance to a particular beacon. I want to have different become trigger different rooms. The only issue is the beacons even at the lowest setting all over lap and I will be turning lights on when I'm not in that room. I wish mobilinc had a way to set triggers at a beacons particular rssi level. Or does it and I'm missing something? Sent from my iPhone using Tapatalk
October 22, 201510 yr Hi Cormacs, One option we have as developers for iBeacon is to enable a ranging feature that constantly ranges the iBeacons to get at a finer grain "distance" estimate. When we tried this during development we ran into two show stoppers: 1. With this option on, the iPhone would drain it's battery in about 2 hours from a full charge. 2. The distance estimate wasn't anywhere close to reliable enough to warrant turning this on for the community. Suggestion on beam shaping your iBeacons: Put something metal between the iBeacon and where you want the RF beam to NOT propagate. While it won't fully stop RF, metal does adversely impact 2.4GHz (BT) range. Wes
October 22, 201510 yr Author I'll play with it some more I didn't have much time last night. It's just would have been so much easier if you could say only trigger if beacon strength is -89dbm. But I guess I could see how that could be a battery hog always analyzing the bt signal Sent from my iPhone using Tapatalk
January 23, 201610 yr I know this is older but I bought kontakt.io beacons (no cheap but feature rich) Their TX power can be set to fine tune and should get results being requested. Edited January 23, 201610 yr by hart2hart
January 25, 201610 yr Author Mine were adjustable too just unreliable. I abandoned them and went back to geofenceing Sent from my iPhone using Tapatalk
September 4, 20169 yr Mine were adjustable too just unreliable. I abandoned them and went back to geofenceing Sent from my iPhone using Tapatalk Would you tell me with which iOS app you were setting up the power? I am in the same boat, I like iBeacons so far but the lack of apps is frustrating. Only one app allows me to change the settings (I want to change the power). And the app is not working.
September 6, 20169 yr rafarataneneces, For iBeacon specifics to the hardware, you'll need to use the manufacturer's app to make adjustments. We use and like the iBeacons and app provided by Estimote. Wes
