Random number in Java code
I have an ISY994i/IR running 4.3.26.
One of the main functions it provides is to give my house a lived in look
when I'm away. I'd like to be able to turn the outside lights on & off a random
number of minutes before & after sunrise & sunset.
I figured out how to create a random number and store it in a variable but I can't
incorporate the variable into the code of the program that controls the
outside lights.
Anyone know how to do this?
Brian
I'm uncertain why you want the variable?  I do a similar thing without...
Front Bedroom Light - [ID 0006][Parent 0001][Run At Startup]
        From    Sunset  -  1 hour
        To      10:00:00PM (same day)
     Or From    Sunrise
        To      Sunrise +  2 hours  (same day)
        Repeat 2 times
           Wait  50 minutes
           Wait  20 minutes  (Random)
           Set 'Light Front Bedroom' On
           Wait  5 minutes  (Random)
           Set 'Light Front Bedroom' Off
           Wait  1 hour and 15 minutes
           Wait  15 minutes  (Random)
           Wait  7 minutes  (Random)
Jon...
Jon...
Thanks...I've not used the Wait command often and wasn't aware there's a Random option. Your solution suits me fine.
Brian
When you "wait 15 minutes (random)", does that mean 15 minutes is the maximum or minimum?
Edited by roblombardo
15 would be the maximum.. anywhere between 0 and 15
Jon...
