Detecting elk F1 key to cntl lights through isy
FarmerGeek
You can use a program:
New Program - [ID 0259][Parent 00B9]
        Elk Keypad 'Hall' 'F1' is Pressed
        Set Scene 'Main / SC - Inner Hall Ceiling' On
Michael.
Link to comment
Share on other sites
I use this function and it works without issue. However, keep in mind that by default the M1 requires you to press a function key twice to activate it since the keys were designed to summon fire, police, etc, and you wouldn't want to do that by an accidental press of a key. You can change this to be a single press in the M1.
Link to comment
 I have it set to Non-alarm and single press.
Sorry. I didn't see you had replied.
I have one programmed like that with non-Alarm and single press. Works fine.
Do you have the ElkRP connected? Nothing else can communicate with the M1 while the ElkRP is connected to it.
Do you see the F-key press in the ISY logs?
Link to comment
