Repairing PLM (Part UTS1C100MDD 10uF 16 volt)
In an earlier post, the subject part was listed as one of the parts that needed replacement. I was preparing an order with mouser.com and all the parts were available except for the subject one. Is there a suitable replacement for this part? If not, can you suggest an online location where I can order a couple? Thanks.
That capacitor is in the 5 volt supply and low ESR is not a big issue.. I used a General Purpose 105 degree C 10uf/16 volt 4mm X 7mm and it seems to be just fine.
http://www.mouser.com/ProductDetail/Nichicon/USV1C100MFD/?qs=sGAEpiMZZMtZ1n0r9vR22TfspN1CfqVcre90UL%2fPITI%3d
If you want to go with a low impedance one. That I found after in a later search and could be a closer match to the original replacement one. 10uf/16V Low Impedance. 4mm X 5mm {shorter but same diameter} 105 degree C
http://www.mouser.com/ProductDetail/Nichicon/UMF1C100MDD/?qs=N9V26swqM1V5w%252b40bRFHyw%3d%3d
Edited by Brian H
Thanks, Brian. I just placed an order.
