ISYLogger - v5.0.2 firmware compatibility?
io_guy,
I recently upgraded to v5.0.2 firmware so I could use your awesome Nodelink program.  That seems to be working great, but ISYLogger doesn't seem to work anymore.  I've tried deleting and re-installing ISYLogger, as well as testing only one variable to be logged.  It seems that there may be an issue with the way the new firmware works with REST requests/responses.  I get a bunch of "Key not found in variable list" entries.  I read the other post about this issue and I'm certain that I haven't added any variables since restarting ISYLogger, or to the ISY itself in quite a few days.
I know you are busy with Nodelink stuff, so I don't want to distract your work on that.  If you have "extra" time, I'd appreciate it if you could take a look.
Below is the log from ISYLogger for the first few minutes after restaring.
Thanks!!
-Todd
2015-12-03 13:06:46 - ISY ISYLogger Server v0.6.5 started
2015-12-03 13:06:46 - Web config server started (http://10.0.0.64:8084)
2015-12-03 13:06:47 - Subscribed to ISY
2015-12-03 13:06:47 - Current logfile has 4 data points
2015-12-03 13:06:48 - HTTP/1.1 101 Switching Protocols
Upgrade: websocket
Connection: Upgrade
Sec-WebSocket-Protocol: ISYSUB
Sec-WebSocket-Accept: (deleted in case it is an encrypted version of my login credentials)=
?i<?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="false"><status>817</status></RestResponse>
2015-12-03 13:07:18 - Heartbeat timeout, re-subscribing to ISY
2015-12-03 13:07:18 - ?~?<?xml version="1.0"?><Event seqnum="0" sid="uuid:52"><control>_4</control><action>5</action><node></node><eventInfo><status>0</status></eventInfo></Event>
2015-12-03 13:07:18 - Subscribed to ISY
2015-12-03 13:07:18 - ?~?<?xml version="1.0"?><Event seqnum="1" sid="uuid:52"><control>_4</control><action>6</action><node></node><eventInfo><status>1</status></eventInfo></Event>
2015-12-03 13:07:18 - ?~#<?xml version="1.0"?><Event seqnum="2" sid="uuid:52"><control>_21</control><action>1.3</action><node></node><eventInfo><zwave nodeid="1" primary="true" suc="false" sis="false" networkEmpty="false" connected="true" extAntenna="true" keyProtected="true" autosleep="true" /></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="3" sid="uuid:52"><control>_1</control><action>8</action><node></node><eventInfo>65E48CFB.0F13</eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="4" sid="uuid:52"><control>_0</control><action>120</action><node></node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="5" sid="uuid:52"><control>_19</control><action>6</action><node></node><eventInfo><se type="156" val="0" /></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="6" sid="uuid:52"><control>_19</control><action>6</action><node></node><eventInfo><se type="157" val="0" /></eventInfo></Event>
2015-12-03 13:07:18 - ?~?<?xml version="1.0"?><Event seqnum="7" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>17 16 9 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="8" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>27 74 D0 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="9" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>27 74 D0 2</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="10" sid="uuid:52"><control>RR</control><action uom="25" prec="0">28</action><node>28 2B 29 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="11" sid="uuid:52"><control>OL</control><action uom="100" prec="0">255</action><node>28 2B 29 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="12" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>28 2B 29 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="13" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>28 2B 29 2</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="14" sid="uuid:52"><control>RR</control><action uom="25" prec="0">28</action><node>28 2D 7 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="15" sid="uuid:52"><control>OL</control><action uom="100" prec="0">255</action><node>28 2D 7 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="16" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>28 2D 7 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="17" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>28 2D 7 2</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="18" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2B 35 A8 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="19" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2B 35 A8 4</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="20" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2B 37 2B 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="21" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2B 37 2B 4</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="22" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2B 37 60 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="23" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2B 37 60 4</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="24" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>2B 38 5D 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="25" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>2B 38 5D 4</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>
2015-12-03 13:07:18 - ?~?<?xml version="1.0"?><Event seqnum="26" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>2D 9A 7B 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="27" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>2D 9A 7B 2</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="28" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>2D 9A 81 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>
2015-12-03 13:07:18 - ?~?<?xml version="1.0"?><Event seqnum="29" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>2D 9A 99 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="30" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>2D 9A 9D 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="31" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>2D 9A 9D 2</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="32" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>2D 9A A7 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="33" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2D 9A A7 2</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="34" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>2D 9D A9 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="35" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2D 9D A9 2</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="36" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F C0 19 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="37" sid="uuid:52"><control>RR</control><action uom="25" prec="0">28</action><node>2F C0 4B 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="38" sid="uuid:52"><control>OL</control><action uom="100" prec="0">255</action><node>2F C0 4B 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="39" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F C0 4B 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="40" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F C0 85 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="41" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F C1 16 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="42" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F C3 47 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="43" sid="uuid:52"><control>RR</control><action uom="25" prec="0">28</action><node>2F C3 47 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="44" sid="uuid:52"><control>OL</control><action uom="100" prec="0">255</action><node>2F C3 47 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="45" sid="uuid:52"><control>RR</control><action uom="25" prec="0">28</action><node>2F C3 4A 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="46" sid="uuid:52"><control>OL</control><action uom="100" prec="0">255</action><node>2F C3 4A 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="47" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F C3 4A 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="48" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F C3 80 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="49" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F C4 4D 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="50" sid="uuid:52"><control>RR</control><action uom="25" prec="0">28</action><node>2F C4 4D 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="51" sid="uuid:52"><control>OL</control><action uom="100" prec="0">255</action><node>2F C4 4D 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="52" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F C4 64 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="53" sid="uuid:52"><control>RR</control><action uom="25" prec="0">28</action><node>2F C4 64 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="54" sid="uuid:52"><control>OL</control><action uom="100" prec="0">255</action><node>2F C4 64 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="55" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F C5 15 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>
2015-12-03 13:07:18 - ?~?<?xml version="1.0"?><Event seqnum="56" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F C6 A9 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="57" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F C6 B7 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="58" sid="uuid:52"><control>RR</control><action uom="25" prec="0">27</action><node>2F C6 B7 1</node><eventInfo></eventInfo><fmtAct>27</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="59" sid="uuid:52"><control>OL</control><action uom="100" prec="0">191</action><node>2F C6 B7 1</node><eventInfo></eventInfo><fmtAct>75%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="60" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F C8 AC 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="61" sid="uuid:52"><control>RR</control><action uom="25" prec="0">28</action><node>2F C8 AC 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="62" sid="uuid:52"><control>OL</control><action uom="100" prec="0">255</action><node>2F C8 AC 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="63" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F C9 23 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="64" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F C9 68 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="65" sid="uuid:52"><control>RR</control><action uom="25" prec="0">28</action><node>2F C9 68 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="66" sid="uuid:52"><control>OL</control><action uom="100" prec="0">255</action><node>2F C9 68 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="67" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F CA AA 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="68" sid="uuid:52"><control>RR</control><action uom="25" prec="0">28</action><node>2F CA AF 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="69" sid="uuid:52"><control>OL</control><action uom="100" prec="0">255</action><node>2F CA AF 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="70" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F CA AF 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="71" sid="uuid:52"><control>RR</control><action uom="25" prec="0">28</action><node>2F CA BF 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="72" sid="uuid:52"><control>OL</control><action uom="100" prec="0">255</action><node>2F CA BF 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="73" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F CA BF 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="74" sid="uuid:52"><control>RR</control><action uom="25" prec="0">28</action><node>2F CA C3 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="75" sid="uuid:52"><control>OL</control><action uom="100" prec="0">255</action><node>2F CA C3 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="76" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F CA C3 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="77" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F CB 3A 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="78" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F CB 63 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="79" sid="uuid:52"><control>ERR</control><action>0</action><node>2F CF 77 1</node><eventInfo></eventInfo></Event>?~?
2015-12-03 13:07:18 - <?xml version="1.0"?><Event seqnum="80" sid="uuid:52"><control>RR</control><action uom="25" prec="0">28</action><node>2F CF 77 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="81" sid="uuid:52"><control>OL</control><action uom="100" prec="0">255</action><node>2F CF 77 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="82" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F CF 77 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="83" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F CF 85 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="84" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F D4 90 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="85" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>2F ED CF 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="86" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F ED CF 3</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="87" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F ED CF 4</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="88" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F ED CF 5</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="89" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>2F ED CF 6</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>
2015-12-03 13:07:18 - ?~?<?xml version="1.0"?><Event seqnum="90" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>2F ED F8 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="91" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F ED F8 3</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="92" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F ED F8 4</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="93" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F ED F8 5</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="94" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>2F ED F8 6</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="95" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>2F EE E9 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="96" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F EE E9 3</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="97" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F EE E9 4</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="98" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F EE E9 5</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="99" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>2F EE E9 6</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="100" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F F0 C0 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="101" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F F0 C0 3</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="102" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F F0 C0 4</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="103" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F F0 C0 5</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="104" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>2F F0 C0 6</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="105" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>31 B0 12 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="106" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>31 B0 12 2</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="107" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>31 B0 41 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="108" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>31 B0 41 2</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="109" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>31 B0 6F 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="110" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>31 B0 6F 2</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="111" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>31 B0 70 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="112" sid="uuid:52"><control>ST</control><action uom="100" prec="0">255</action><node>31 B0 70 2</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="113" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>33 F F 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="114" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>33 F F 2</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="115" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>33 F F 3</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="116" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>33 F F 4</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="117" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>33 F F 5</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="118" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>33 F F 6</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="119" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>33 F F 7</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="120" sid="uuid:52"><control>ST</control><action uom="100" prec="0">0</action><node>33 F F 8</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="121" sid="uuid:52"><control>USRNUM</control><action uom="70" prec="0">0</action><node>ZW003_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="122" sid="uuid:52"><control>BATLVL</control><action uom="51" prec="0">96</action><node>ZW003_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="123" sid="uuid:52"><control>ST</control><action uom="11" prec="0">0</action><node>ZW003_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="124" sid="uuid:52"><control>USRNUM</control><action uom="70" prec="0">0</action><node>ZW004_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="125" sid="uuid:52"><control>ST</control><action uom="11" prec="0">0</action><node>ZW004_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="126" sid="uuid:52"><control>BATLVL</control><action uom="51" prec="0">96</action><node>ZW004_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="127" sid="uuid:52"><control>ST</control><action uom="78" prec="0">100</action><node>ZW011_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="128" sid="uuid:52"><control>BATLVL</control><action uom="51" prec="0">92</action><node>ZW012_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="129" sid="uuid:52"><control>ST</control><action uom="11" prec="0">0</action><node>ZW012_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="130" sid="uuid:52"><control>USRNUM</control><action uom="70" prec="0">0</action><node>ZW012_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="131" sid="uuid:52"><control>CLISMD</control><action uom="25" prec="0">0</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>0</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="132" sid="uuid:52"><control>GV2</control><action uom="25" prec="0">1</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>1</fmtAct><fmtName>Heartbeat</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="133" sid="uuid:52"><control>CLIHUM</control><action uom="51" prec="0">43</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>43%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="134" sid="uuid:52"><control>ST</control><action uom="14" prec="1">678</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>67.8??</fmtAct><fmtName>Temperature</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="135" sid="uuid:52"><control>CLISPH</control><action uom="14" prec="0">68</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>68??</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="136" sid="uuid:52"><control>CLISPC</control><action uom="14" prec="0">78</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>78??</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="137" sid="uuid:52"><control>GV1</control><action uom="51" prec="0">36</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>36%</fmtAct><fmtName>Humidity Setpoint</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="138" sid="uuid:52"><control>GV4</control><action uom="25" prec="0">0</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>0</fmtAct><fmtName>Fan On Time</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="139" sid="uuid:52"><control>CLIFRS</control><action uom="80" prec="0">0</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>Off</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="140" sid="uuid:52"><control>CLIHCS</control><action uom="66" prec="0">0</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>Idle</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="141" sid="uuid:52"><control>CLIMD</control><action uom="67" prec="0">1</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>Heat</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="142" sid="uuid:52"><control>GV1</control><action uom="25" prec="0">0</action><node>n001_ecobee3_sen1</node><eventInfo></eventInfo><fmtAct>0</fmtAct><fmtName>Occupancy</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="143" sid="uuid:52"><control>ST</control><action uom="14" prec="1">685</action><node>n001_ecobee3_sen1</node><eventInfo></eventInfo><fmtAct>68.5??</fmtAct><fmtName>Temperature</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="144" sid="uuid:52"><control>GV1</control><action uom="25" prec="0">0</action><node>n001_ecobee3_sen2</node><eventInfo></eventInfo><fmtAct>0</fmtAct><fmtName>Occupancy</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="145" sid="uuid:52"><control>ST</control><action uom="14" prec="1">659</action><node>n001_ecobee3_sen2</node><eventInfo></eventInfo><fmtAct>65.9??</fmtAct><fmtName>Temperature</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="146" sid="uuid:52"><control>GV1</control><action uom="25" prec="0">0</action><node>n001_ecobee3_sen3</node><eventInfo></eventInfo><fmtAct>0</fmtAct><fmtName>Occupancy</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="147" sid="uuid:52"><control>ST</control><action uom="14" prec="1">654</action><node>n001_ecobee3_sen3</node><eventInfo></eventInfo><fmtAct>65.4??</fmtAct><fmtName>Temperature</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="148" sid="uuid:52"><control>GV1</control><action uom="25" prec="0">0</action><node>n001_ecobee3_sen4</node><eventInfo></eventInfo><fmtAct>0</fmtAct><fmtName>Occupancy</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="149" sid="uuid:52"><control>ST</control><action uom="14" prec="1">714</action><node>n001_ecobee3_sen4</node><eventInfo></eventInfo><fmtAct>71.4??</fmtAct><fmtName>Temperature</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="150" sid="uuid:52"><control>GV11</control><action uom="25" prec="0">3</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>3</fmtAct><fmtName>Season</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="151" sid="uuid:52"><control>GV10</control><action uom="25" prec="0">337</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>337</fmtAct><fmtName>Day of Year</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="152" sid="uuid:52"><control>GV9</control><action uom="25" prec="0">2015</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>2015</fmtAct><fmtName>Year</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="153" sid="uuid:52"><control>GV8</control><action uom="25" prec="0">3</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>3</fmtAct><fmtName>Day of Month</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="154" sid="uuid:52"><control>GV7</control><action uom="47" prec="0">12</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>December</fmtAct><fmtName>Month</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="155" sid="uuid:52"><control>GV6</control><action uom="25" prec="0">4</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>4</fmtAct><fmtName>Day of Week</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="156" sid="uuid:52"><control>GV5</control><action uom="25" prec="0">49</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>49</fmtAct><fmtName>Week</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="157" sid="uuid:52"><control>GV4</control><action uom="25" prec="0">1</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>1</fmtAct><fmtName>Odd/Even Day</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="158" sid="uuid:52"><control>GV3</control><action uom="25" prec="0">484627</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>484627</fmtAct><fmtName>Minutes This Year</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="159" sid="uuid:52"><control>GV2</control><action uom="25" prec="0">7</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>7</fmtAct><fmtName>Minutes</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="160" sid="uuid:52"><control>GV1</control><action uom="25" prec="0">13</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>13</fmtAct><fmtName>Hour</fmtName></Event>?~
2015-12-03 13:07:18 - ?<?xml version="1.0"?><Event seqnum="161" sid="uuid:52"><control>GV3</control><action uom="14" prec="0">61</action><node>n001_isydata_sun</node><eventInfo></eventInfo><fmtAct>61??</fmtAct><fmtName>Zenith</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="162" sid="uuid:52"><control>GV2</control><action uom="14" prec="0">29</action><node>n001_isydata_sun</node><eventInfo></eventInfo><fmtAct>29??</fmtAct><fmtName>Elevation</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="163" sid="uuid:52"><control>GV1</control><action uom="14" prec="0">198</action><node>n001_isydata_sun</node><eventInfo></eventInfo><fmtAct>198??</fmtAct><fmtName>Azimuth</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="164" sid="uuid:52"><control>_4</control><action>5</action><node></node><eventInfo><status>0</status></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="165" sid="uuid:52"><control>_4</control><action>6</action><node></node><eventInfo><status>1</status></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="166" sid="uuid:52"><control>_11</control><action>1</action><node></node><eventInfo><value>55</value><unit> F</unit></eventInfo></Event>
2015-12-03 13:07:18 - ?~?<?xml version="1.0"?><Event seqnum="167" sid="uuid:52"><control>_11</control><action>2</action><node></node><eventInfo><value>61</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="168" sid="uuid:52"><control>_11</control><action>3</action><node></node><eventInfo><value>41</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="169" sid="uuid:52"><control>_11</control><action>4</action><node></node><eventInfo><value>55</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="170" sid="uuid:52"><control>_11</control><action>5</action><node></node><eventInfo><value>47.3</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="171" sid="uuid:52"><control>_11</control><action>6</action><node></node><eventInfo><value>93</value><unit> %</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="172" sid="uuid:52"><control>_11</control><action>8</action><node></node><eventInfo><value>29.99</value><unit> inHg</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="173" sid="uuid:52"><control>_11</control><action>10</action><node></node><eventInfo><value>54</value><unit> F</unit></eventInfo></Event>
2015-12-03 13:07:19 - ?~?<?xml version="1.0"?><Event seqnum="174" sid="uuid:52"><control>_11</control><action>11</action><node></node><eventInfo><value>3</value><unit> mph</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="175" sid="uuid:52"><control>_11</control><action>13</action><node></node><eventInfo><value>SE</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="176" sid="uuid:52"><control>_11</control><action>15</action><node></node><eventInfo><value>7</value><unit> mph</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="177" sid="uuid:52"><control>_11</control><action>17</action><node></node><eventInfo><value>0.16</value><unit> inches</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="178" sid="uuid:52"><control>_11</control><action>18</action><node></node><eventInfo><value>65</value><unit> %</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="179" sid="uuid:52"><control>_11</control><action>22</action><node></node><eventInfo><value>0</value><unit> inches/day</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="180" sid="uuid:52"><control>_11</control><action>23</action><node></node><eventInfo><value>0</value><unit> inches</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="181" sid="uuid:52"><control>_11</control><action>24</action><node></node><eventInfo><value>0</value><unit> inches</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="182" sid="uuid:52"><control>_11</control><action>25</action><node></node><eventInfo><value>100</value><unit> </unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="183" sid="uuid:52"><control>_11</control><action>26</action><node></node><eventInfo><value>0</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="184" sid="uuid:52"><control>_11</control><action>27</action><node></node><eventInfo><value>2</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="185" sid="uuid:52"><control>_11</control><action>28</action><node></node><eventInfo><value>14</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="186" sid="uuid:52"><control>_11</control><action>29</action><node></node><eventInfo><value>5</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="187" sid="uuid:52"><control>_11</control><action>30</action><node></node><eventInfo><value>54</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="188" sid="uuid:52"><control>_11</control><action>31</action><node></node><eventInfo><value>63</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="189" sid="uuid:52"><control>_11</control><action>32</action><node></node><eventInfo><value>45</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="190" sid="uuid:52"><control>_11</control><action>33</action><node></node><eventInfo><value>72</value><unit> %</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="191" sid="uuid:52"><control>_11</control><action>34</action><node></node><eventInfo><value>4</value><unit> mph</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="192" sid="uuid:52"><control>_11</control><action>35</action><node></node><eventInfo><value>7</value><unit> mph</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="193" sid="uuid:52"><control>_11</control><action>36</action><node></node><eventInfo><value>0</value><unit> inches</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="194" sid="uuid:52"><control>_11</control><action>37</action><node></node><eventInfo><value>0</value><unit> inches</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="195" sid="uuid:52"><control>_11</control><action>38</action><node></node><eventInfo><value>0</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="196" sid="uuid:52"><control>_11</control><action>39</action><node></node><eventInfo><value>0</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="197" sid="uuid:52"><control>_11</control><action>40</action><node></node><eventInfo><value>0</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="198" sid="uuid:52"><control>_11</control><action>41</action><node></node><eventInfo><value>3</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="199" sid="uuid:52"><control>_11</control><action>42</action><node></node><eventInfo><value>55</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="200" sid="uuid:52"><control>_11</control><action>43</action><node></node><eventInfo><value>63</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="201" sid="uuid:52"><control>_11</control><action>44</action><node></node><eventInfo><value>48</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="202" sid="uuid:52"><control>_11</control><action>45</action><node></node><eventInfo><value>74</value><unit> %</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="203" sid="uuid:52"><control>_11</control><action>46</action><node></node><eventInfo><value>0.43</value><unit> inches</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="204" sid="uuid:52"><control>_11</control><action>47</action><node></node><eventInfo><value>0</value><unit> inches</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="205" sid="uuid:52"><control>_11</control><action>48</action><node></node><eventInfo><value>4</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="206" sid="uuid:52"><control>_11</control><action>49</action><node></node><eventInfo><value>0</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="207" sid="uuid:52"><control>_11</control><action>50</action><node></node><eventInfo><value>14</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="208" sid="uuid:52"><control>_11</control><action>51</action><node></node><eventInfo><value>4</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="209" sid="uuid:52"><control>_11</control><action>100</action><node></node><eventInfo><value>2015/12/03 13:04:13</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="210" sid="uuid:52"><control>_22</control><action>1</action><node></node><eventInfo><totalCostToday>0.000000</totalCostToday><totalCostPeriod>0.000000</totalCostPeriod><totalUsagePeriod>0.000000</totalUsagePeriod><cycleEndTime>2015/12/31 11:59:59 PM</cycleEndTime></eventInfo></Event>
2015-12-03 13:07:19 - HTTP/1.1 101 Switching Protocols
Upgrade: websocket
Connection: Upgrade
?{<?xml version="1.0" encoding="UTF-8"?><SubscriptionResponse><SID>uuid:52</SID><duration>0</duration></SubscriptionResponse>
2015-12-03 13:07:25 - ?~?<?xml version="1.0"?><Event seqnum="211" sid="uuid:52"><control>_0</control><action>120</action><node></node><eventInfo></eventInfo></Event>
2015-12-03 13:07:34 - ?~?<?xml version="1.0"?><Event seqnum="212" sid="uuid:52"><control>GV3</control><action uom="25" prec="0">484628</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>484628</fmtAct><fmtName>Minutes This Year</fmtName></Event>
2015-12-03 13:07:34 - ?~?<?xml version="1.0"?><Event seqnum="213" sid="uuid:52"><control>_1</control><action>3</action><node></node><eventInfo>[n001_isydata]      GV3 484628 (uom=25 prec=0)</eventInfo></Event>
2015-12-03 13:07:35 - ?~?<?xml version="1.0"?><Event seqnum="214" sid="uuid:52"><control>_1</control><action>0</action><node></node><eventInfo><id>1EF</id><nsr>151204 03:00:30</nsr></eventInfo></Event>
2015-12-03 13:07:35 - ?~?<?xml version="1.0"?><Event seqnum="215" sid="uuid:52"><control>_1</control><action>0</action><node></node><eventInfo><id>1EF</id><on /><nr /><r>151203 13:07:37</r><f>151203 13:07:37</f><s>31</s></eventInfo></Event>
2015-12-03 13:07:36 - <?xml version="1.0"?><Event seqnum="216" sid="uuid:52"><control>_1</control><action>6</action><node></node><eventInfo><var type="1" id="59"><prec>0</prec><val>2155</val><ts>20151203 13:07:38</ts></var></eventInfo></Event>
2015-12-03 13:07:36 - ?~
2015-12-03 13:07:36 - Key not found in variable list
2015-12-03 13:07:36 - ?~?<?xml version="1.0"?><Event seqnum="218" sid="uuid:52"><control>_1</control><action>6</action><node></node><eventInfo><var type="1" id="61"><prec>0</prec><val>10</val><ts>20151203 13:07:38</ts></var></eventInfo></Event>
2015-12-03 13:07:36 - ?~?<?xml version="1.0"?><Event seqnum="217" sid="uuid:52"><control>_1</control><action>6</action><node></node><eventInfo><var type="1" id="60"><prec>0</prec><val>21554</val><ts>20151203 13:07:38</ts></var></eventInfo></Event>
2015-12-03 13:07:36 - ?~?<?xml version="1.0"?><Event seqnum="219" sid="uuid:52"><control>_1</control><action>7</action><node></node><eventInfo><var type="1" id="59"><init>2155</init><prec>0</prec></var></eventInfo></Event>
2015-12-03 13:07:36 - ?~?<?xml version="1.0"?><Event seqnum="220" sid="uuid:52"><control>_1</control><action>6</action><node></node><eventInfo><var type="2" id="39"><prec>0</prec><val>2155</val><ts>20151203 13:07:38</ts></var></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="221" sid="uuid:52"><control>_1</control><action>7</action><node></node><eventInfo><var type="2" id="39"><init>2155</init><prec>0</prec></var></eventInfo></Event>
2015-12-03 13:07:36 - ?~?<?xml version="1.0"?><Event seqnum="222" sid="uuid:52"><control>_1</control><action>3</action><node></node><eventInfo>[VAR  2   39 ]       2155</eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="223" sid="uuid:52"><control>_1</control><action>0</action><node></node><eventInfo><id>10A</id><on /><nr /><r>151203 13:07:39</r><f>151203 13:07:39</f><s>31</s></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="224" sid="uuid:52"><control>_1</control><action>0</action><node></node><eventInfo><id>10B</id><on /><nr /><r>151203 13:07:39</r><f>151203 13:07:39</f><s>31</s></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="225" sid="uuid:52"><control>_1</control><action>0</action><node></node><eventInfo><id>107</id><on /><rr /><r>151203 13:07:39</r><f>151203 13:07:39</f><s>31</s></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="226" sid="uuid:52"><control>_1</control><action>0</action><node></node><eventInfo><id>106</id><on /><rr /><r>151203 13:07:39</r><f>151203 13:07:39</f><s>21</s></eventInfo></Event>
This is likely a one-off variable that doesn't decode properly (it works fine here).  I have a few changes that I'll cut in a new release - there's extra debug info to see what variable is the issue.
Cool.  Thanks.  I wonder if it's related to the ecobee or ISYdata variables coming from the new nodes?  Otherwise, the variables are the same as I had when running v4.3.26 firmware, I think.  What is strange is that I don't see the names of the variables coming over the logged data in ISYLogger, but the drop-down list is populated with a big list of strings.
I'll do a quick test to see if I add a new variable name to the ISY, does it come up in the list.  Or is it somehow remembering my variable names from an old installation?  I deleted the config.xml file in my debugging, but the names don't show up there anyways.  Are they stored somewhere else?
The variable list comes from a different call than the subscription you pasted.  The names are also pulled dynamically, not stored (only the ID is stored).
My quick test did add the new variable name to the list in the drop-down, so that's working.
Yeah, I figured it was only the ID that's stored.  That's all that shows up in the config.xml file.
Still seems to have the same problem using your new v0.6.6.
Additionally info:  the two variables that I'm sending to the log file do show up in the log file, but their values don't change in the file, when I know they do in real life.
Here's the first few lines of the log window:
2015-12-03 14:38:13 - ISY ISYLogger Server v0.6.6 started
2015-12-03 14:38:13 - Web config server started (http://10.0.0.64:8084)
2015-12-03 14:38:14 - Subscribed to ISY
2015-12-03 14:38:14 - Current logfile has 29 data points
2015-12-03 14:38:14 - ?~?<?xml version="1.0"?><Event seqnum="0" sid="uuid:61"><control>_4</control><action>5</action><node></node><eventInfo><status>0</status></eventInfo></Event>
2015-12-03 14:38:14 - ?~?<?xml version="1.0"?><Event seqnum="1" sid="uuid:61"><control>_4</control><action>6</action><node></node><eventInfo><status>1</status></eventInfo></Event>?~#<?xml version="1.0"?><Event seqnum="2" sid="uuid:61"><control>_21</control><action>1.3</action><node></node><eventInfo><zwave nodeid="1" primary="true" suc="false" sis="false" networkEmpty="false" connected="true" extAntenna="true" keyProtected="true" autosleep="true" /></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="3" sid="uuid:61"><control>_1</control><action>8</action><node></node><eventInfo>65E48CFB.0F13</eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="4" sid="uuid:61"><control>_0</control><action>120</action><node></node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="5" sid="uuid:61"><control>_19</control><action>6</action><node></node><eventInfo><se type="156" val="0" /></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="6" sid="uuid:61"><control>_19</control><action>6</action><node></node><eventInfo><se type="157" val="0" /></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="7" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>17 16 9 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="8" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>27 74 D0 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="9" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>27 74 D0 2</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="10" sid="uuid:61"><control>RR</control><action uom="25" prec="0">28</action><node>28 2B 29 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="11" sid="uuid:61"><control>OL</control><action uom="100" prec="0">255</action><node>28 2B 29 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="12" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>28 2B 29 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="13" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>28 2B 29 2</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="14" sid="uuid:61"><control>RR</control><action uom="25" prec="0">28</action><node>28 2D 7 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="15" sid="uuid:61"><control>OL</control><action uom="100" prec="0">255</action><node>28 2D 7 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="16" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>28 2D 7 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="17" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>28 2D 7 2</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="18" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2B 35 A8 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="19" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2B 35 A8 4</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="20" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2B 37 2B 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="21" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2B 37 2B 4</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="22" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2B 37 60 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="23" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2B 37 60 4</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="24" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2B 38 5D 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="25" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2B 38 5D 4</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="26" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2D 9A 7B 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="27" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2D 9A 7B 2</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="28" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2D 9A 81 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="29" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2D 9A 99 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="30" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2D 9A 9D 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="31" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2D 9A 9D 2</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="32" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2D 9A A7 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="33" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2D 9A A7 2</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="34" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2D 9D A9 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="35" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2D 9D A9 2</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="36" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2F C0 19 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="37" sid="uuid:61"><control>RR</control><action uom="25" prec="0">28</action><node>2F C0 4B 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="38" sid="uuid:61"><control>OL</control><action uom="100" prec="0">255</action><node>2F C0 4B 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="39" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2F C0 4B 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="40" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F C0 85 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="41" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F C1 16 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="42" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2F C3 47 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="43" sid="uuid:61"><control>RR</control><action uom="25" prec="0">28</action><node>2F C3 47 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="44" sid="uuid:61"><control>OL</control><action uom="100" prec="0">255</action><node>2F C3 47 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="45" sid="uuid:61"><control>RR</control><action uom="25" prec="0">28</action><node>2F C3 4A 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="46" sid="uuid:61"><control>OL</control><action uom="100" prec="0">255</action><node>2F C3 4A 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="47" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F C3 4A 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="48" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F C3 80 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="49" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F C4 4D 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="50" sid="uuid:61"><control>RR</control><action uom="25" prec="0">28</action><node>2F C4 4D 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="51" sid="uuid:61"><control>OL</control><action uom="100" prec="0">255</action><node>2F C4 4D 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="52" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2F C4 64 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="53" sid="uuid:61"><control>RR</control><action uom="25" prec="0">28</action><node>2F C4 64 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="54" sid="uuid:61"><control>OL</control><action uom="100" prec="0">255</action><node>2F C4 64 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="55" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F C5 15 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="56" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F C6 A9 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="57" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F C6 B7 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="58" sid="uuid:61"><control>RR</control><action uom="25" prec="0">27</action><node>2F C6 B7 1</node><eventInfo></eventInfo><fmtAct>27</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="59" sid="uuid:61"><control>OL</control><action uom="100" prec="0">191</action><node>2F C6 B7 1</node><eventInfo></eventInfo><fmtAct>75%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="60" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F C8 AC 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="61" sid="uuid:61"><control>RR</control><action uom="25" prec="0">28</action><node>2F C8 AC 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="62" sid="uuid:61"><control>OL</control><action uom="100" prec="0">255</action><node>2F C8 AC 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="63" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F C9 23 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="64" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F C9 68 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="65" sid="uuid:61"><control>RR</control><action uom="25" prec="0">28</action><node>2F C9 68 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="66" sid="uuid:61"><control>OL</control><action uom="100" prec="0">255</action><node>2F C9 68 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="67" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F CA AA 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="68" sid="uuid:61"><control>RR</control><action uom="25" prec="0">28</action><node>2F CA AF 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="69" sid="uuid:61"><control>OL</control><action uom="100" prec="0">255</action><node>2F CA AF 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="70" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2F CA AF 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="71" sid="uuid:61"><control>RR</control><action uom="25" prec="0">28</action><node>2F CA BF 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="72" sid="uuid:61"><control>OL</control><action uom="100" prec="0">255</action><node>2F CA BF 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="73" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2F CA BF 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="74" sid="uuid:61"><control>RR</control><action uom="25" prec="0">28</action><node>2F CA C3 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="75" sid="uuid:61"><control>OL</control><action uom="100" prec="0">255</action><node>2F CA C3 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="76" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2F CA C3 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="77" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F CB 3A 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="78" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F CB 63 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="79" sid="uuid:61"><control>ERR</control><action>0</action><node>2F CF 77 1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="80" sid="uuid:61"><control>RR</control><action uom="25" prec="0">28</action><node>2F CF 77 1</node><eventInfo></eventInfo><fmtAct>28</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="81" sid="uuid:61"><control>OL</control><action uom="100" prec="0">255</action><node>2F CF 77 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="82" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F CF 77 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="83" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F CF 85 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="84" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F D4 90 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="85" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2F ED CF 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="86" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F ED CF 3</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="87" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F ED CF 4</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="88" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F ED CF 5</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="89" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2F ED CF 6</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="90" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2F ED F8 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="91" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F ED F8 3</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="92" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F ED F8 4</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="93" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F ED F8 5</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="94" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2F ED F8 6</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="95" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2F EE E9 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="96" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F EE E9 3</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="97" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F EE E9 4</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="98" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F EE E9 5</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="99" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>2F EE E9 6</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="100" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F F0 C0 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="101" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F F0 C0 3</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="102" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F F0 C0 4</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="103" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F F0 C0 5</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="104" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>2F F0 C0 6</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="105" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>31 B0 12 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="106" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>31 B0 12 2</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="107" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>31 B0 41 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>
2015-12-03 14:38:14 - ?~?<?xml version="1.0"?><Event seqnum="108" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>31 B0 41 2</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="109" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>31 B0 6F 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="110" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>31 B0 6F 2</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="111" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>31 B0 70 1</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="112" sid="uuid:61"><control>ST</control><action uom="100" prec="0">255</action><node>31 B0 70 2</node><eventInfo></eventInfo><fmtAct>100%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="113" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>33 F F 1</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="114" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>33 F F 2</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="115" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>33 F F 3</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="116" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>33 F F 4</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="117" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>33 F F 5</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="118" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>33 F F 6</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="119" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>33 F F 7</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="120" sid="uuid:61"><control>ST</control><action uom="100" prec="0">0</action><node>33 F F 8</node><eventInfo></eventInfo><fmtAct>0%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="121" sid="uuid:61"><control>USRNUM</control><action uom="70" prec="0">0</action><node>ZW003_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="122" sid="uuid:61"><control>BATLVL</control><action uom="51" prec="0">96</action><node>ZW003_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="123" sid="uuid:61"><control>ST</control><action uom="11" prec="0">0</action><node>ZW003_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="124" sid="uuid:61"><control>USRNUM</control><action uom="70" prec="0">0</action><node>ZW004_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="125" sid="uuid:61"><control>ST</control><action uom="11" prec="0">0</action><node>ZW004_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="126" sid="uuid:61"><control>BATLVL</control><action uom="51" prec="0">96</action><node>ZW004_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="127" sid="uuid:61"><control>ST</control><action uom="78" prec="0">100</action><node>ZW011_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="128" sid="uuid:61"><control>BATLVL</control><action uom="51" prec="0">92</action><node>ZW012_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="129" sid="uuid:61"><control>ST</control><action uom="11" prec="0">0</action><node>ZW012_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="130" sid="uuid:61"><control>USRNUM</control><action uom="70" prec="0">0</action><node>ZW012_1</node><eventInfo></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="131" sid="uuid:61"><control>CLISMD</control><action uom="25" prec="0">0</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>0</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="132" sid="uuid:61"><control>GV2</control><action uom="25" prec="0">1</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>1</fmtAct><fmtName>Heartbeat</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="133" sid="uuid:61"><control>CLIHUM</control><action uom="51" prec="0">46</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>46%</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="134" sid="uuid:61"><control>ST</control><action uom="14" prec="0">68</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>68??</fmtAct><fmtName>Temperature</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="135" sid="uuid:61"><control>CLISPH</control><action uom="14" prec="0">68</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>68??</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="136" sid="uuid:61"><control>CLISPC</control><action uom="14" prec="0">78</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>78??</fmtAct></Event>
2015-12-03 14:38:15 - ?~?<?xml version="1.0"?><Event seqnum="137" sid="uuid:61"><control>GV1</control><action uom="51" prec="0">36</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>36%</fmtAct><fmtName>Humidity Setpoint</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="138" sid="uuid:61"><control>GV4</control><action uom="25" prec="0">0</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>0</fmtAct><fmtName>Fan On Time</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="139" sid="uuid:61"><control>CLIFRS</control><action uom="80" prec="0">0</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>Off</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="140" sid="uuid:61"><control>CLIHCS</control><action uom="66" prec="0">0</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>Idle</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="141" sid="uuid:61"><control>CLIMD</control><action uom="67" prec="0">1</action><node>n001_ecobee3</node><eventInfo></eventInfo><fmtAct>Heat</fmtAct></Event>?~?<?xml version="1.0"?><Event seqnum="142" sid="uuid:61"><control>GV1</control><action uom="25" prec="0">1</action><node>n001_ecobee3_sen1</node><eventInfo></eventInfo><fmtAct>1</fmtAct><fmtName>Occupancy</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="143" sid="uuid:61"><control>ST</control><action uom="14" prec="0">69</action><node>n001_ecobee3_sen1</node><eventInfo></eventInfo><fmtAct>69??</fmtAct><fmtName>Temperature</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="144" sid="uuid:61"><control>GV1</control><action uom="25" prec="0">1</action><node>n001_ecobee3_sen2</node><eventInfo></eventInfo><fmtAct>1</fmtAct><fmtName>Occupancy</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="145" sid="uuid:61"><control>ST</control><action uom="14" prec="1">661</action><node>n001_ecobee3_sen2</node><eventInfo></eventInfo><fmtAct>66.1??</fmtAct><fmtName>Temperature</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="146" sid="uuid:61"><control>GV1</control><action uom="25" prec="0">1</action><node>n001_ecobee3_sen3</node><eventInfo></eventInfo><fmtAct>1</fmtAct><fmtName>Occupancy</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="147" sid="uuid:61"><control>ST</control><action uom="14" prec="1">654</action><node>n001_ecobee3_sen3</node><eventInfo></eventInfo><fmtAct>65.4??</fmtAct><fmtName>Temperature</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="148" sid="uuid:61"><control>GV1</control><action uom="25" prec="0">1</action><node>n001_ecobee3_sen4</node><eventInfo></eventInfo><fmtAct>1</fmtAct><fmtName>Occupancy</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="149" sid="uuid:61"><control>ST</control><action uom="14" prec="1">718</action><node>n001_ecobee3_sen4</node><eventInfo></eventInfo><fmtAct>71.8??</fmtAct><fmtName>Temperature</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="150" sid="uuid:61"><control>GV11</control><action uom="25" prec="0">3</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>3</fmtAct><fmtName>Season</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="151" sid="uuid:61"><control>GV10</control><action uom="25" prec="0">337</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>337</fmtAct><fmtName>Day of Year</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="152" sid="uuid:61"><control>GV9</control><action uom="25" prec="0">2015</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>2015</fmtAct><fmtName>Year</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="153" sid="uuid:61"><control>GV8</control><action uom="25" prec="0">3</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>3</fmtAct><fmtName>Day of Month</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="154" sid="uuid:61"><control>GV7</control><action uom="47" prec="0">12</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>December</fmtAct><fmtName>Month</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="155" sid="uuid:61"><control>GV6</control><action uom="25" prec="0">4</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>4</fmtAct><fmtName>Day of Week</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="156" sid="uuid:61"><control>GV5</control><action uom="25" prec="0">49</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>49</fmtAct><fmtName>Week</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="157" sid="uuid:61"><control>GV4</control><action uom="25" prec="0">1</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>1</fmtAct><fmtName>Odd/Even Day</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="158" sid="uuid:61"><control>GV3</control><action uom="25" prec="0">484718</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>484718</fmtAct><fmtName>Minutes This Year</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="159" sid="uuid:61"><control>GV2</control><action uom="25" prec="0">38</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>38</fmtAct><fmtName>Minutes</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="160" sid="uuid:61"><control>GV1</control><action uom="25" prec="0">14</action><node>n001_isydata</node><eventInfo></eventInfo><fmtAct>14</fmtAct><fmtName>Hour</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="161" sid="uuid:61"><control>GV3</control><action uom="14" prec="0">70</action><node>n001_isydata_sun</node><eventInfo></eventInfo><fmtAct>70??</fmtAct><fmtName>Zenith</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="162" sid="uuid:61"><control>GV2</control><action uom="14" prec="0">20</action><node>n001_isydata_sun</node><eventInfo></eventInfo><fmtAct>20??</fmtAct><fmtName>Elevation</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="163" sid="uuid:61"><control>GV1</control><action uom="14" prec="0">219</action><node>n001_isydata_sun</node><eventInfo></eventInfo><fmtAct>219??</fmtAct><fmtName>Azimuth</fmtName></Event>?~?<?xml version="1.0"?><Event seqnum="164" sid="uuid:61"><control>_4</control><action>5</action><node></node><eventInfo><status>0</status></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="165" sid="uuid:61"><control>_4</control><action>6</action><node></node><eventInfo><status>1</status></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="166" sid="uuid:61"><control>_11</control><action>1</action><node></node><eventInfo><value>54</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="167" sid="uuid:61"><control>_11</control><action>2</action><node></node><eventInfo><value>61</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="168" sid="uuid:61"><control>_11</control><action>3</action><node></node><eventInfo><value>41</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="169" sid="uuid:61"><control>_11</control><action>4</action><node></node><eventInfo><value>54</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="170" sid="uuid:61"><control>_11</control><action>5</action><node></node><eventInfo><value>48</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="171" sid="uuid:61"><control>_11</control><action>6</action><node></node><eventInfo><value>97</value><unit> %</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="172" sid="uuid:61"><control>_11</control><action>8</action><node></node><eventInfo><value>30.03</value><unit> inHg</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="173" sid="uuid:61"><control>_11</control><action>10</action><node></node><eventInfo><value>54</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="174" sid="uuid:61"><control>_11</control><action>11</action><node></node><eventInfo><value>0</value><unit> mph</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="175" sid="uuid:61"><control>_11</control><action>13</action><node></node><eventInfo><value>N/A</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="176" sid="uuid:61"><control>_11</control><action>15</action><node></node><eventInfo><value>0</value><unit> mph</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="177" sid="uuid:61"><control>_11</control><action>17</action><node></node><eventInfo><value>0.22</value><unit> inches</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="178" sid="uuid:61"><control>_11</control><action>18</action><node></node><eventInfo><value>33</value><unit> %</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="179" sid="uuid:61"><control>_11</control><action>22</action><node></node><eventInfo><value>0</value><unit> inches/day</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="180" sid="uuid:61"><control>_11</control><action>23</action><node></node><eventInfo><value>0</value><unit> inches</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="181" sid="uuid:61"><control>_11</control><action>24</action><node></node><eventInfo><value>0</value><unit> inches</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="182" sid="uuid:61"><control>_11</control><action>25</action><node></node><eventInfo><value>100</value><unit> </unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="183" sid="uuid:61"><control>_11</control><action>26</action><node></node><eventInfo><value>0</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="184" sid="uuid:61"><control>_11</control><action>27</action><node></node><eventInfo><value>2</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="185" sid="uuid:61"><control>_11</control><action>28</action><node></node><eventInfo><value>14</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="186" sid="uuid:61"><control>_11</control><action>29</action><node></node><eventInfo><value>5</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="187" sid="uuid:61"><control>_11</control><action>30</action><node></node><eventInfo><value>54</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="188" sid="uuid:61"><control>_11</control><action>31</action><node></node><eventInfo><value>63</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="189" sid="uuid:61"><control>_11</control><action>32</action><node></node><eventInfo><value>45</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="190" sid="uuid:61"><control>_11</control><action>33</action><node></node><eventInfo><value>72</value><unit> %</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="191" sid="uuid:61"><control>_11</control><action>34</action><node></node><eventInfo><value>4</value><unit> mph</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="192" sid="uuid:61"><control>_11</control><action>35</action><node></node><eventInfo><value>7</value><unit> mph</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="193" sid="uuid:61"><control>_11</control><action>36</action><node></node><eventInfo><value>0</value><unit> inches</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="194" sid="uuid:61"><control>_11</control><action>37</action><node></node><eventInfo><value>0</value><unit> inches</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="195" sid="uuid:61"><control>_11</control><action>38</action><node></node><eventInfo><value>0</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="196" sid="uuid:61"><control>_11</control><action>39</action><node></node><eventInfo><value>0</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="197" sid="uuid:61"><control>_11</control><action>40</action><node></node><eventInfo><value>0</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="198" sid="uuid:61"><control>_11</control><action>41</action><node></node><eventInfo><value>3</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="199" sid="uuid:61"><control>_11</control><action>42</action><node></node><eventInfo><value>55</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="200" sid="uuid:61"><control>_11</control><action>43</action><node></node><eventInfo><value>63</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="201" sid="uuid:61"><control>_11</control><action>44</action><node></node><eventInfo><value>48</value><unit> F</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="202" sid="uuid:61"><control>_11</control><action>45</action><node></node><eventInfo><value>74</value><unit> %</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="203" sid="uuid:61"><control>_11</control><action>46</action><node></node><eventInfo><value>0.43</value><unit> inches</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="204" sid="uuid:61"><control>_11</control><action>47</action><node></node><eventInfo><value>0</value><unit> inches</unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="205" sid="uuid:61"><control>_11</control><action>48</action><node></node><eventInfo><value>4</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="206" sid="uuid:61"><control>_11</control><action>49</action><node></node><eventInfo><value>0</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="207" sid="uuid:61"><control>_11</control><action>50</action><node></node><eventInfo><value>14</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="208" sid="uuid:61"><control>_11</control><action>51</action><node></node><eventInfo><value>4</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="209" sid="uuid:61"><control>_11</control><action>100</action><node></node><eventInfo><value>2015/12/03 14:34:11</value><unit></unit></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="210" sid="uuid:61"><control>_22</control><action>1</action><node></node><eventInfo><totalCostToday>0.000000</totalCostToday><totalCostPeriod>0.000000</totalCostPeriod><totalUsagePeriod>0.000000</totalUsagePeriod><cycleEndTime>2015/12/31 11:59:59 PM</cycleEndTime></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="211" sid="uuid:61"><control>_0</control><action>120</action><node></node><eventInfo></eventInfo></Event>
2015-12-03 14:38:15 - HTTP/1.1 101 Switching Protocols
Upgrade: websocket
Connection: Upgrade
Sec-WebSocket-Protocol: ISYSUB
Sec-WebSocket-Accept: ---=
?{<?xml version="1.0" encoding="UTF-8"?><SubscriptionResponse><SID>uuid:61</SID><duration>0</duration></SubscriptionResponse>
2015-12-03 14:38:19 - ?~?<?xml version="1.0"?><Event seqnum="212" sid="uuid:61"><control>DON</control><action>1</action><node>2D 9A 9D 1</node><eventInfo></eventInfo></Event>
2015-12-03 14:38:19 - ?~?<?xml version="1.0"?><Event seqnum="213" sid="uuid:61"><control>_1</control><action>3</action><node></node><eventInfo>[  2D 9A 9D 1]      DON   1</eventInfo></Event>
2015-12-03 14:38:19 - ?~?<?xml version="1.0"?><Event seqnum="214" sid="uuid:61"><control>_1</control><action>0</action><node></node><eventInfo><id>E9</id><on /><rr /><r>151203 14:38:20</r><f>151203 14:38:20</f><s>22</s></eventInfo></Event>
2015-12-03 14:38:19 - ?~?<?xml version="1.0"?><Event seqnum="215" sid="uuid:61"><control>_1</control><action>0</action><node></node><eventInfo><id>1E5</id><on /><nr /><r>151203 14:38:20</r><f>151203 14:38:20</f><s>31</s></eventInfo></Event>
2015-12-03 14:38:19 - ?~?<?xml version="1.0"?><Event seqnum="216" sid="uuid:61"><control>_1</control><action>0</action><node></node><eventInfo><id>139</id><on /><nr /><r>151203 14:38:20</r><f>151203 14:38:02</f><s>22</s></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="217" sid="uuid:61"><control>_1</control><action>0</action><node></node><eventInfo><id>1E6</id><on /><nr /><r>151203 14:38:20</r><f>151203 14:38:20</f><s>31</s></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="218" sid="uuid:61"><control>_1</control><action>0</action><node></node><eventInfo><id>139</id><on /><nr /><r>151203 14:38:20</r><f>151203 14:38:20</f><s>21</s></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="219" sid="uuid:61"><control>_1</control><action>6</action><node></node><eventInfo><var type="1" id="65"><prec>0</prec><val>956</val><ts>20151203 14:38:20</ts></var></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="220" sid="uuid:61"><control>_1</control><action>6</action><node></node><eventInfo><var type="1" id="68"><prec>0</prec><val>145</val><ts>20151203 14:38:20</ts></var></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="221" sid="uuid:61"><control>_1</control><action>7</action><node></node><eventInfo><var type="1" id="65"><init>956</init><prec>0</prec></var></eventInfo></Event>?~?<?xml version="1.0"?><Event seqnum="222" sid="uuid:61"><control>_1</control><action>7</action><node></node><eventInfo><var type="1" id="68"><init>145</init><prec>0</prec></var></eventInfo></Event>
2015-12-03 14:38:19 - Key not found in variable list (1-65"><prec>0</pre)
2015-12-03 14:38:19 - Key not found in variable list (1-68"><prec>0</pre)
2015-12-03 14:38:24 - ?~
2015-12-03 14:38:24 - <?xml version="1.0"?><Event seqnum="223" sid="uuid:61"><control>_1</control><action>6</action><node></node><eventInfo><var type="2" id="30"><prec>0</prec><val>275</val><ts>20151203 14:38:25</ts></var></eventInfo></Event>
2015-12-03 14:38:24 - Key not found in variable list (2-30"><prec>0</pre)
2015-12-03 14:38:24 - ?~?<?xml version="1.0"?><Event seqnum="225" sid="uuid:61"><control>_1</control><action>0</action><node></node><eventInfo><id>1E6</id><on /><nr /><r>151203 14:38:25</r><f>151203 14:38:25</f><s>31</s></eventInfo></Event>
2015-12-03 14:38:24 - ?~?<?xml version="1.0"?><Event seqnum="226" sid="uuid:61"><control>_1</control><action>0</action><node></node><eventInfo><id>EA</id><on /><rr /><r>151203 14:38:25</r><f>151203 14:38:10</f><s>22</s></eventInfo></Event>
2015-12-03 14:38:24 - ?~?<?xml version="1.0"?><Event seqnum="227" sid="uuid:61"><control>_1</control><action>0</action><node></node><eventInfo><id>EA</id><on /><rr /><r>151203 14:38:25</r><f>151203 14:38:25</f><s>21</s></eventInfo></Event>
2015-12-03 14:38:24 - ?~?<?xml version="1.0"?><Event seqnum="224" sid="uuid:61"><control>_1</control><action>3</action><node></node><eventInfo>[VAR  2   30 ]       275</eventInfo></Event>
2015-12-03 14:38:24 - ?~?<?xml version="1.0"?><Event seqnum="228" sid="uuid:61"><control>_1</control><action>6</action><node></node><eventInfo><var type="1" id="21"><prec>0</prec><val>4140</val><ts>20151203 14:38:25</ts></var></eventInfo></Event>
And here's the first few lines of a log file:
Time,s_Homeness,s_Motion_Factor
12/03/2015 14:24:01,3274,3790
12/03/2015 14:24:31,3274,3820
12/03/2015 14:25:06,3274,3750
12/03/2015 14:25:36,3274,3750
12/03/2015 14:26:06,3274,3750
12/03/2015 14:26:36,3274,3750
12/03/2015 14:27:06,3274,3750
12/03/2015 14:27:36,3274,3750
12/03/2015 14:28:07,3274,3750
12/03/2015 14:28:37,3274,3750
12/03/2015 14:29:07,3274,3750
12/03/2015 14:29:37,3274,3750
12/03/2015 14:30:07,3274,3750
12/03/2015 14:30:37,3274,3750
12/03/2015 14:31:07,3274,3750
12/03/2015 14:31:37,3274,3750
12/03/2015 14:32:07,3274,3750
12/03/2015 14:32:37,3274,3750
12/03/2015 14:33:07,3274,3750
12/03/2015 14:33:37,3274,3750
12/03/2015 14:34:07,3274,3750
12/03/2015 14:34:37,3274,3750
12/03/2015 14:35:07,3274,3750
12/03/2015 14:35:37,3274,3750
12/03/2015 14:36:07,3274,3750
12/03/2015 14:36:37,3274,3750
12/03/2015 14:37:07,3274,3750
12/03/2015 14:38:44,3523,4130
12/03/2015 14:39:14,3523,4130
12/03/2015 14:39:44,3523,4130
12/03/2015 14:40:14,3523,4130
12/03/2015 14:40:44,3523,4130
I do see that it shows "key not found in variable list" items above have 1-65 and 1-68 variables.  There isn't anything weird about their variable names other than they may be too long??
1-65 is "Occupancy_Motion" with a precision of "0"
1-68 is "Front_Entry_Motion_Cumulative" with a precision of "0"
Those are underscores, not spaces if that matters.
Edited by Toddimus
That log is all I needed, I can reproduce here now.  Will get a fix out this weekend.
Awesome!  Thanks again.
Take your time.
New version of ISYLogger is working great!  Thanks.
