Help programming motion from alarm to control light
danbutter
I have DSCLink running and it is working ok.
I have a motion hooked to the panel change a state variable in the ISY.
I then have a program to turn on light when variable state is seen.
It does. I then have a wait 5 mins and turn light off.
However it doesn't wait.
The second the motion sensor sees no motion the light goes off again.
What am I missing?
Post your program (right click on the program name, select Copy to Clipboard).
I tried this one and the light comes on as desired, but never turns off.
Laundry Motion - [ID 0009][Parent 0001]
        $Laundry_Light is 1
        Set 'Basement / Laundry Light' On
        Wait  5 minutes
        Set 'Basement / Laundry Light' Off
and then I tried this one and the light is only on for as long as motion is seen.
        $Laundry_Light is 1
        Wait  5 minutes
I'm pretty new at all this so it is probably something simple, but usually I can stumble through and figure things out.  Not yet on this one though.
I'm open to ideas!
danbutter
Between the two examples it sounds like the Variable is changing value when motion stops.  If the problem is not clear post the Program setting the Variable.
In the first example the Wait is terminated when Variable $Laundry_Light no longer equals 1.   The Wait terminating is normal Wait operation when the Program If Condition causes the Program to Trigger while in the Wait.  This leaves the Laundry Light On as there is nothing in Else clause.
In the second example the Wait has no statements after the Wait so it has no affect (does not actually Wait).  When the Variable changes state after motion stops the Program is Triggered, the If is now False so the Else executes.
OK. This makes sense.
Simple option is to tart the timer after motion is last seen.
Laundrylight is 1
Turn light on
Wait 5 min
Turn light off
danbutter
This concept of the IF being evaluated again during the processing of the THEN seems so weird to me.  I don't think I've run into a programming language that does that because often in the THEN statement you modify variables that make the IF no longer true (like a counter).
kohai
The Wait and Repeat statements have the same characteristics.  For some functions it makes more sense.
If Control 'motionsensor-sensor' is switched On
    Set 'something' On
    Wait 5 minutes
    Set 'something' Off
As long as the motion sensor senses motion the Wait is refreshed with a full 5 minutes.  Only when no motion is sensed for 5 minutes does 'something' turn Off.
Edited by LeeG
kohai
    Set 'something' On
    Wait 5 minutes
    Set 'something' Off
Interesting, I guess that makes sense... kind of like a WHILE but different.
Thanks a lot for all the help.  I ended up doing this:
        $Laundry_Light is 1
        Wait  1 minute
...and it works great.  When it was going on and off I realized I don't need to have it wait so long since the motion seems to see you breathe down there.
Thanks again!
If the variable isn't needed for other programs, there are a few ways to do this without the variable. Which either makes it more or less complex :) ...  but it is always good to know multiple ways of solving these problems....
Here is one way, using the motion sensor commands to directly control the program:
        Control 'Motion Sensor-Sensor' is switch On
     Or Control 'Motion Sensor-Sensor' is not switched Off
        Wait 1 minute
With the above If construct, the "Then" clause will run when the sensor sends the On command, and the "Else" clause will run when the sensor sends the Off command.  The "is not" is used to specify to run the Else clause when the statement is true.
Here is another way, and is the way I use, as it results in slightly faster response.  Whether the faster response is noticeable or not I don't know, but I set this up right after I had set up an open/close sensor which responds slowly (I'm not sure if the slow response is due to the sensor itself, the ISY or the target device).
1) Change the motion sensor to only send On commands (assuming the one you are using can do this).
2) Link the motion sensor directly with the target device (Basement / Laundry Light).  That is, make the motion sensor a controller for the light, and the light a responder to the sensor.  Mine are linked via a scene, but I honestly don't remember if a scene is required or not.
Doing these 2 steps removes the ISY from the "turn on" command.  The sensor directly turns on the lights.
Then you only need the program to turn the lights off, which could look like this:
        Control 'Motion Sensor-Sensor' is switched On
        Wait 1 minute
   - No Actions
This program essentially just starts a timer when the sensor sends the On command, and will turn off the light after 1 minute without seeing another On command.
Note that to get the exact same behavior as the your program, you'd need to make the wait time 1 minute + the Off time of your sensor.  This timer starts with the On, while yours starts with the Off.
-Kyle
Kman,
I don't believe that this was an insteon motion sensor (at least it was not stated as such).  It sounded like a motion sensor wired to some security panel which, in turn, triggered the variable.
danbutter, thanks for this thread.  I had the same issue (although with an Insteon motion sensor) and trying to fix it, I came up with basically the two programs you did in post #3.  Great minds and all that.   :)
Thanks to everyone for the help.  I think I understand the THEN and WAIT better now.
Edited by jasont
Kman,
Ah ... missed that in the first post.  Makes sense that he needs the variable then.
Not to hijack this thread, but I've got a similar if/then/else question.
My scenario:
1. IF the front door is opened, turn on the chandelier.
2. Only turn OFF the light if the front door is closed AND there isn't any motion inside for 2 minutes. (e.g. if I invite someone in and close the door because it is cold I don't want the light to turn off on me)
I created the following:
Front Door - Chandelier - [iD 000C][Parent 0001]
        $sAlarmZ01_FrontDoor is 1
    And $sAlarmZ17_FrontEntryMotion is 1
        Resource 'Centralite-EntryChandelierOn'
        Wait  2 minutes
        Resource 'Centralite-EntryChandelierOff'
The problem this has is that the ELSE is always being queued when the inside motion sensor triggers.  If I'm inside the house and I have the chandelier ON, then it will turn it OFF 2 minutes after sensing motion (because the door isn't open too).  I don't see a way to do an embedded IF inside the ELSE.
Programmatically, I don't know the state of the chandelier -- I don't know if it is On or Off.  Maybe in the future I'll create a really awesome Centralite interface to ISY.  I can only tell it to go on or off.
My initial reaction would be to break this into two programs (I will let you figure out the variables and alarm system resources).
door is open
and door is not closed
then
turn on light
else
enable second program
run second program (then path)
second program (normally disabled):
if
motion sensor is triggered
then
wait 2 minutes
turn off light
disable second (this) program
else
nothing
Are there going to be cases here where you may have manually turned on the lights and want them to stay on regardless of whether the door subsequently opens or closes?
Perhaps what you should consider is to put these into a program folder with a condition such as:
If third program is true
then run the programs in this folder
third program
if
control light is turned on
and control light is not turned off
then
nothing
else
nothing
Hopefully, these give you some ideas how to proceed.
      380k
