Using KeypadLinc "Off" button in a program
I have a 6-button keypadlinc (On, Off, A, B, C, and D buttons).  When I linked the keypad to the ISY, it created 5 items (On, A, B, C, and D).  I can use those in my programs just fine.  If there a way to use the "Off" button in a condition e.g. if Off is pressed, then do something?
Yes. Treat the ON and OFF buttons as a single insteon switch (apparently with the default name of "on", but it can be renamed anything you want). The progrm statement is no different than with any other switch....
Control/status " on" is set off
Do something
Do something
Thanks!  That worked.
