Garage door opened at 2:57am by itself! Help
Below is a log of the events.  Can anyone explain why my garage door opened at 2:57am?  The scene "All On Off"  is to turn off any lights left on at 2:57am.  That scene does not include the iolinc for the garage.
Scene:All On Off                           Off             0        Fri 2016/01/08 02:57:00 AM     Program Log
Overhead garage door-Sensor    Status      100%   Fri 2016/01/08 02:57:01 AM     System Log
Overhead garage door-Relay      Status        100%   Fri 2016/01/08 02:57:01 AM     System Log
Porch keypad - Garage Door- H  Status     100%   Fri 2016/01/08 02:57:01 AM     System Log
Overhead garage door-Relay     Status        Query  Fri 2016/01/08 02:57:16 AM     Program Log
Overhead garage door-Relay     Status         0%       Fri 2016/01/08 02:57:16 AM     System Log
Scene:ISY                                    Status         Query  Fri 2016/01/08 03:00:01 AM     Program Log
Overhead garage door-Relay    Status        100%   Fri 2016/01/08 03:00:05 AM     System Log
Deck Lights                                 Status           0%     Fri 2016/01/08 03:00:08 AM     System Log
Overhead garage door-Relay    Status          0%      Fri 2016/01/08 03:00:09 AM     System Log
Scene:DeckL                                  Off            0        Fri 2016/01/08 03:00:13 AM     Program Log
Porch Keypad F Deck Lights       Status          0%      Fri 2016/01/08 03:00:13 AM    System Log
Edited by Blackbird
Do you have trigger reverse enabled in the I/O Link?
how do I check that?
Go to the node in the Admin Console and select options. If its checked then yes its enabled if not at least we removed one area from concern.
No the trigger reverse box is not checked on the options
Just momentary B and LED on TX
Next step is to do a visual confirmation the wires leading into the various I/O ports are properly seated and no bare wire is present. I've seen lots of installs where the bare wire was too long and some random movement caused the two adjacent wires to connect and initiate a random open / close.
Don't rely on simply looking at it plugged in, wiggle the wire and see. If nothing happens unplug it and really look and pull on the wires to make sure all of them are seated and tighten down.
I will check for sure but does seem like a coincidence that its at the same time as the all off scene
I agree and the next step is to really eye ball to make sure this device is indeed NOT part of this scene at all. Is it fair to say this never happen before and this program has been active for awhile and no previous issues have been seen?
Blackbird
The I/O Linc Sensor Status was logged before I/O Linc Relay which suggests something else moved the door.  The I/O Linc Sensor is a Controller only node, not changed by an Insteon command.
I was more curious about why the log shows a query for the GDO I/O Linc:
Blackbird
Do you mean something other than insteon or ISY?  They are both within the same second
Edited by Blackbird
This was from the night before and all was fine
Bedroom Light                            Status      0%     Thu 2016/01/07 12:46:28 AM System Log
Scene:All On Off                          Off          0        Thu 2016/01/07 02:57:00 AM Program Log
Living room above chair light    Status      0%     Thu 2016/01/07 02:57:00 AM System Log
Scene:ISY                                    Status      Query Thu 2016/01/07 03:00:00 AM Program Log
Edited by Blackbird
Can you offer more back ground as to how your home is set up to use the GDO I/O Link? I see you have a KPL assigned to the unit is this case?
Also, can you shed some light as to any programs / scenes have the GDO included.
Blackbird
Since the I/O Linc Sensor could not be affected by the All On Off Scene directly, I would look at the Log before what is posted in post 1.  Also something invoked the All On Off Scene which also adds to the areas to examine.  You've indicated the All On Off Scene has no reference to the I/O Linc so something else is communicating with that device Sensor and Relay.
Are you on Windows 7?
Ideals are peaceful - History is violent
windows 8
Assuming its still present in the search field type in *Snipping Tool*. If its there you can launch it and it will allow you to perform a image capture.
I thought there was a different way post your programs
On the program just right click and select copy to clip board. Then come to this post and right click and paste. I thought you meant an image from your Admin Console
The Snipping Tool has been continued through Win 8 and Win 10.
These are the only programs I have for the garage I/o linc
Cant remember what this does but one of you recommended it
Overhead Garage door relay off -
        Status  'Overhead garage door-Relay' is On
        Wait  15 seconds
        Set 'Overhead garage door-Relay' Query
Pushover notification when door is closed
Garage Door Closed -
        Status  'Overhead garage door-Sensor' is Off
        Send Notification to 'Pushover' content 'Garage Overhead door closed'
Notification when door is opened
Overhead Garage Door Open Notification
        Status  'Overhead garage door-Sensor' is On
        Send Notification to 'email' content 'Garage Overhead Door sensor Open'
        Send Notification to 'Pushover' content 'Garage Overhead Door sensor Open'
This is the scene for the overhead garage door.  I used to control the door from the key pad in the house but disabled it a while ago so the keypad would only light up when the door is open
This is the all on off scene which I have set to a mini remote and a fast on and of on the kitchen light.
This is my program that turns all the lights off at night incase I forgot to do it.  This is the program I believe triggered the garage door to open as the door opened at 2:57am
All off at night -
        Time is  2:57:00AM
        Set Scene 'All On Off' Off
Edited by Blackbird
Blackbird
I have not been able to relate posted Log entries.to the Programs.  If this type event happens with any regularity suggest having Event Viewer at LEVEL 3 running for a few minutes before the activity begins so detail information can be collected and posted.
