Upgrading 99i/IR PRO to ISY994i?
I currently run an old ISY 99i?IR PRO with about 20 dual band dimmer and switch modules.  I typically only use one program daily.  I have a new ISY994i that I'd like to install in place of the old '99i.  Where can I find a step-by-step (I am no computer genius) instruction on how to make this upgrade?
Current ISY99i is FW 3.3.10.  Current Admin console is 4.3.26.
I assume I'll need to make a backup file, pull the old ISY, install the new ISY, then restore the file?  Must be more to it than that.  Thanks in advance.
Terry
Thank you Brian.  Guess that has been asked about a lot.  :oops:
  • 3 months later...
Am I safe to assume the instructions linked above would work identically if I am replacing an ISY994i with a ISY994i PRO?
If there a recommended time to perform this where the Transfer of Module will take less time? (eg do the guys not work weekends or perhaps?)
No.. click on Purchase Modules in admin console (help > purchase modules)
I'm not certain that it isn't effective immediately.
Jon...
If you are replacing an ISY994i with a ISY994iPRO. The PRO should already be enabled as it was purchased with the PRO feature enabled from the factory.
As above, the PRO upgrade is software only. Add it as a 'module' and its effective immediately you install it.
Queuing the writes up in batches is a much nicer way to go about things.
