espann Posted March 25, 2016 Author Posted March 25, 2016 On 3/2/2016 at 2:07 AM, stusviews said: I don't know why grouping is not available for you. Which ISY? which firmware? which UI? Hi Stu, now once again the motion detector icon is showing "ungrouped", as you show above. And when I do a device restore it appears to write to the device and while writing it does show the normal "grouped" icon, but when it finishes writing, it goes back to the ungrouped icon. And in this mode I cant setup or control a scene.
jerlands Posted March 25, 2016 Posted March 25, 2016 On 3/25/2016 at 9:36 PM, espann said: Hi Stu, now once again the motion detector icon is showing "ungrouped", as you show above. And when I do a device restore it appears to write to the device and while writing it does show the normal "grouped" icon, but when it finishes writing, it goes back to the ungrouped icon. And in this mode I cant setup or control a scene. In admin console Help > About what does it show for Firmware and UI versions? both versions should always be the same. Jon...
espann Posted March 25, 2016 Author Posted March 25, 2016 On 3/25/2016 at 9:39 PM, jerlands said: In admin console Help > About what does it show for Firmware and UI versions? both versions should always be the same. Jon... They are both the same, Firmware v4.3.26 (2015-10-11:35:11) UI v4.3.26 (2015-10-11:35:11)
espann Posted March 25, 2016 Author Posted March 25, 2016 On 3/25/2016 at 9:39 PM, jerlands said: In admin console Help > About what does it show for Firmware and UI versions? both versions should always be the same. Jon... Well, even though the icons are showing that strange ungrouped appearance, it does seem to be working and controlling my scenes properly. Now I just have to replace the OutLetLinc dimmer, which I'm pretty sure is broken..
jerlands Posted March 25, 2016 Posted March 25, 2016 On 3/25/2016 at 9:36 PM, espann said: Hi Stu, now once again the motion detector icon is showing "ungrouped", as you show above. And when I do a device restore it appears to write to the device and while writing it does show the normal "grouped" icon, but when it finishes writing, it goes back to the ungrouped icon. And in this mode I cant setup or control a scene. Grouping devices has no effect on adding a node to a scene or how it operates but only helps with organization by allowing the device nodes to be opened and collapsed in the tree. Why you're having issue with the motion sensor ungrouping is puzzling but I think I'd try and group them again by right clicking on node and select "Group Devices." Jon...
stusviews Posted March 25, 2016 Posted March 25, 2016 Devices that include more that one choice have a square icon with a + (grouped) or a - (ungrouped). Click the icon to change the grouping mode.
