January 12, 201610 yr I have installed per the instructions on a pi. The error code I get when trying to get to any of the menus other than the Main web browser screen for the NodeLink Server is: "HTTP/1.0 404 Not Found Connection: close "
January 12, 201610 yr You mean if you try to hit the "System Config"? Please post everything from the NodeLink log. Edited January 12, 201610 yr by io_guy
January 12, 201610 yr Author You mean if you try to hit the "System Config"? Yes "System Config" or "Devices" Thanks Paul I saw the host name was a problem. After changing it to ISY I can access the other screens. logfile_2016-01-12.txt Edited January 12, 201610 yr by Pcarp
