Portal - HAD Variable / Weather Errors
I have noted using the portal sometimes causes the following error messages to appear while using the HAD interface.
Not sure why this happens but wanted to report it, if it wasn't known.
Hi Teken,
I checked the logs, and the error was caused by a timeout.
This means that from portal's perspective, the ISY was still online (the ISY socket was not closed), but still it did not respond.
I will PM you an error log for your IP.
Benoit.
Error Logs sent and thank you Sir!
