only run then if device is on for x seconds
bilsk
Posted (edited)
all, i'm having not much luck with trying, and i am guessing i am not using the right search terms.
i'd like for the hidden door sensors to only beep if after 7 seconds the door is still open.
if
       control sensor is on  <for 7 seconds>
then
        set buzzer relay on
        wait 1 second
        set buzzer relay off
else
        set buzzer off
i tried a few things but it isn't straight forward, i can;t use wait statements in [if] for example
anyone have an idea that works ?
Edited by bilsk
You'll need two programs and a spare device (you'll need to query the device because you can't query a battery powered device). Link the sensor as a controller of the spare device.
        Control 'sensor' is switched On
        Wait 7 seconds
        Run 'program 2' (If)
Program 2
        Status 'spare device' is not off
        set ...
       set ...
Posted (edited)
This may provide a single Program approach
OpenDoor - [iD 002F][Parent 0001]
        Control '2C.71.C2.1 - Door Sensor' is switched On
     Or Control '2C.71.C2.1 - Door Sensor' is not switched Off
        Set 'ApplianceLinc' On
        Wait  7 seconds
        Set 'ApplianceLinc' Off
Edited by LeeG
bilsk
Apologies for poor sample.  Seven second Wait replaced the 1 second Wait rather than being added where it should have been.
        Wait  7 seconds
        Wait  1 second
Thanks Larry for the heads up.
      37.9k
      378.9k
