February 15, 201610 yr Hi Im sure this is user error, but...I have created one node on the Nodelink config page. It is intended to test Nodelink as I cont have supported devices at the moment (will get GEM Ethernet module). As such the device type is the Extra Isy Data, or whatever it was called in the dropdown (no longer there since I created one it is removed from the list). I enabled sun position and Ontario Time-of Use Node (whatever that does). I see two grouped devices on ISY Main called ISY Data and Sun Position. However, if I select either there are no fields on the main device page. See screenshot: Here is the log from the config web page: 2016-02-15 23:38:34 - ISY NodeLink Server v0.3.5 started 2016-02-15 23:38:34 - Web config server started (http://192.168.xxx.xxx:8090) 2016-02-15 23:38:34 - ISY resolved to 192.168.xxx.xxx 2016-02-15 23:38:36 - ISY Error: Duplicate node names exist on the ISY (KP 1L) 2016-02-15 23:38:36 - ISY Error: Duplicate node names exist on the ISY (KP 1R) 2016-02-15 23:38:36 - ISY Error: Duplicate node names exist on the ISY (KP 2L) 2016-02-15 23:38:36 - ISY Error: Duplicate node names exist on the ISY (KP 2R) 2016-02-15 23:38:36 - ISY Error: Duplicate node names exist on the ISY (KP 3L) 2016-02-15 23:38:36 - ISY Error: Duplicate node names exist on the ISY (KP 3R) 2016-02-15 23:38:36 - ISY Error: Duplicate node names exist on the ISY (KP 4L) 2016-02-15 23:38:36 - ISY Error: Duplicate node names exist on the ISY (KP 4R) 2016-02-15 23:38:36 - ISY Error: Duplicate node names exist on the ISY (Ofc-PC-EMlZ008) 2016-02-15 23:38:36 - ISY Error: Duplicate node names exist on the ISY (Bmt-Theta-SSlZ020) 2016-02-15 23:38:36 - ISY Error: Duplicate node names exist on the ISY (Gar-Fridge-SSlZ022) 2016-02-15 23:38:36 - ISY Error: Duplicate node names exist on the ISY (Ofc-Rack-SSlZ028) 2016-02-15 23:38:36 - Auto-Update: Checking for program update... 2016-02-15 23:38:36 - Auto-Update: No web update available Any suggestions? [EDIT: Note I am running nodelink on a RPi in a console ssh window for testing purposes (not as a service etc. It is running) [Edit 2: I have rebooted both ISY and RPi and loaded the zip file twice and loaded the node multiple times.] Thanks Edited February 16, 201610 yr by ccclapp
February 16, 201610 yr Install zip and reboot again. If they don't show the basic template in the ISY it's an ISY problem. There's nothing in your log.
