MobiLinc portal integration keeps disconnecting
I am not sure whether I am posting this in the right place, but I am having trouble with my ISY 499i PRO staying visible to Mobilinc Connect and MobiLinc Pro on the iPhone/ iPad.  It doesn't matter if I am inside my LAN or outside.  If i restart my ISY, it connects again.
I am running 4.3.26
I recently replaced my router and cable modem, but was having this trouble before.
Hi Matt,
If you are using a fixed IP address, please use the Google DNS IP of 8.8.4.4 for the DNS IP field.
If you are still having trouble, please send us the following to support@mobilinc.com:
- Screenshot of your ISY's Admin Console->Configuration Tab.
- Screenshot of your ISY's Admin Console->Help->About.
- Your ISY's Error Log under Tools->Error Log.
Wes
Thanks Wes
I'll do that.  I am already using 8.8.4.4 for DNS
Matt
  • 4 weeks later...
It turns out my sonos music system was causing a broadcast storm on my network. It's been up for 10 days. Now to figure the sonos out.
