Leak Sensors (REV2.3)
I purchased a couple of these from Dell. Apparently they are an older technology since the Heartbeat does not display as ON in the heartbeat node. Am I correct? If so, I will design the program to notify me when the Heartbeat reports its status as ON (which I assume will only occur when the battery is low). Good price on these but I didn't ask for their REV number. Oh, well.
That is not correct.   I have a REV2.3 hardware Leak Sensor.   It is an I2CS device and does report Heartbeat On every 24 hours (nominal).
There is no Low Bat for Leak Sensor.
Edited by LeeG
You are correct, Lee. A check today shows that the sensor did, in fact, report a heartbeat 24 hours later.
  • 2 months later...
I was about to return the leak sensor because of this... I too in fact created a program to report if there is a lack of heartbeat... but since it does not show a status normally, I can not accomplish this...
Furnace - Variable Control 2 - [iD 000A][Parent 0001]
        Control 'Furnace Water-Heartbeat' is switched On
     Or Control 'Furnace Water-Heartbeat' is switched Off
        $sLeakFurnace  = 1
        Wait  25 hours
        $sLeakFurnace  = 2
Leak Sensor Problem - [iD 000E][Parent 0001]
             Time is  9:00:00AM
          Or Time is  6:00:00PM
    And (
             $sLeakSump is not 1
          Or $sLeakFurnace is not 1
        Send Notification to 'All' content 'Leak Sensor Problem'
How can I force a heartbeat status?
Regards,
S
