Net-Resource: Failed connecting to api.prowlapp.com
You need to download the Dashboard then upper right hand corner you'll see a wrench looking icon.
In admin console (Help > About) then download from Current Release, Betas, and Bug Reports for the correct firmware version you have installed.
Link to dashboard is located bottom of page.
Jon...
I must be blind, unable to see "HTTPS Server Settings." in the Administrative Console, print screen will be usefull
The "Verify" setting is not in the Administration Console.  You have to use the Dashboard.  See post #2
Jon...
Here's an image of the setting in Dashboard > Click wrench Icon > Network
Jon...
Thanks Jon, mine don't look like yours :?
Edited by Plau
I didn't realize you were using the 99i...  Couple things I noticed.
1.) The Dashboard and Admin Console UI used needs to be the same version as your firmware (see your first image "version.jpg.")  You need to clear your Java Cache then download the correct versions (if your Admin Console is also wrong see Help > About)
2.) Your network settings are UPnP.  You might change this to DHCP and reserve the address in your router (after you install the correct Dashboard and if needed Admin Console.)  That could be your problem.
Jon...
Unfortunately the dashboard for 3.3.10 is missing, anyway I'm not sure issue came from this side, the system was up and running for more than 3 years.
I did not notice any change on my network or hardwares since issue.
You might look at the network and see if ISY is visible.
Jon...
he is accessible by admin console or dashboard, I'm not sure to understand where you want going  ?
Edited by Plau
You are using UPnP and not DHCP.   You might research this a little on the Forum or look at this thread.
The fact Prowl notifications isn't working possibly has to do with network issue.
Jon..
I switched to dhcp and made ip reservation in my  router, but still the same error message, I use another ha software (domoticz) and prowl work as it is (same api key) I have no idea where investigated now!
3.3.10 non-pro cannot connect to most SSL servers now - because it only supports ciphers that are now considered so insecure that most web sites have now removed them.
To use any of the network notification services you'll either have to upgrade to a 994 - or setup a reverse proxy to handle SSL for the old ISY.
Michael.
Edited by MWareman
