Honeywell TCC - v0.4.0 Single Thermostat Errors
I am setting up a second ISY for my parents house and have Nodelink 0.4.0 installed on a Raspi for their system.  When I add their TCC thermostat credentials, the thermostat page returns:
HTTP/1.0 404 Not Found Connection: close
And the log shows the following (I enabled verbose thermostat logging but don't get any more details):
2016-03-12 03:57:29 - TCC Login Error: Error getting response stream (Write: The authentication or decryption has failed.): SendFailure [tstat]
2016-03-12 03:57:29 - TCC Login:  [tstat]
2016-03-12 03:57:29 - TCC Get Error: Error getting response stream (Write: The authentication or decryption has failed.): SendFailure [tstat]
2016-03-12 03:57:29 - TCC Data:  [tstat]
The credeantials are correct (verified by logging into the TCC website).
Edited to add:
I just tried my system (functional on 0.3.5) on 0.4.0 and it is returning this in the log:
2016-03-11 22:08:23 - TCC Get Error: The remote server returned an error: (500) Internal Server Error. [z3stat]
2016-03-11 22:08:23 - TCC Get Error: The remote server returned an error: (500) Internal Server Error. [z2tstat]
2016-03-11 22:08:24 - TCC Get Error: The remote server returned an error: (500) Internal Server Error. [z1tstat]
2016-03-11 22:08:24 - TCC Get Error: The remote server returned an error: (500) Internal Server Error. [mdftstat]
And the same 404 error when attempting to access any of the thermostat pages.  This system runs Win 8.
Edited by stmrocket
Yep, I broke TCC multi-stat support in 0.3.7.  I have it fixed now, will wait until tomorrow to release (to see what else doesn't work in this version).
No problem.  I rolled back to 0.3.5 and all is well.  I noticed TCC errors when I was testing 0.3.7 but never looked into them as I rolled back when it didn't work with RainMachine and I just assumed it was something related to that.  Guess I should have looked into it further...
As always, thank you for the great programs and support!
Version 0.4.1 is working great with my multi thermostat system.  I can't test it on my single thermostat install as the network is down at the site but I will update once I have tested it.
