Mobilinc and IST 5.03
No. Well, it crashes for me.
Edited by andyf0
I tested with MLHD. I created a new profile and synced to avoid stepping on my existing config. No issues.
As tested
iPad 2: iOS 9.3b7
ISY: 5.0.3a
Elk M1G+XEP: Latest firmware
I specifically did not retest cameras and ZoneMinder since not relevant.
I also did not test with MLConnect as I did not want to risk messing that up.
As tested
iPad 2: iOS 9.3b7
ISY: 5.0.3a
Are you testing a private build? I don't think 5.0.3a is publicly available. My MobiLincHD hangs as soon as I touch the screen, or until it starts to download current status.
Not running IOS Beta either.
Edited by andyf0
ISY 5.0.3a(lpha) is available.
MLHD 4.7 production.
I haven't had any issues on any iOS version, 9.2 or any 9.3betas
Hi Andy,
We're not aware of any 5.x firmware issues with MobiLinc that would cause a crash to occur. We have seen in a couple of cases a program issue appear in 5.x where the data from the ISY is mismatched (status of a program vs. the actual program list). We have a workaround solution in house that we are testing, but a quick way to see if this is the issue is to go back to the latest firmware 4.x and restore your 4.x backup to confirm that the issue goes away.
Wes
There is no way I'm going back considering the days of effort I spent moving up to 5.0.3.
However, I will correct my earlier statement. After uninstalling and re-installing MobiLincHD it seems to be working well. Of course I lost all my customizations but that is a small price to pay to have GeoFencing back.
The only issue is the thermostat display for a Honeywell Z-Wave thermostat. It's a little wonky, it's the same for both thermostats in my system. Picture attached.
Thanks Andy. How many decimal places does the Admin Console show for the thermostat? Seems like it's more than what MobiLinc expected.
Wes
Well, AdminConsole shows 78.0 as does the Heat & Cool Setpoint. Event Viewer shows (uom=17, prec=1) when activity takes place.
Dashboard.jnlp does report temperature x 10. 76 degrees is reported as 760 etc.
Edited by andyf0
