Unable to set-up IFTTT on portal
I can't find the set-up section, specifically Select Tool or Connectivity.  I imagine its something simple, but have been searching and can't find anything on this...
On wiki it says, "On portal, IFTTT configuration is in Select Tool | Connectivity | IFTTT".  But I don't see that.  I see:
Portal Integration UDI
"Offline"  "Registered"
Action Services
my username  "Registered"  a button for "revoke" and "more Info"
Requested Services
this section is blank/empty
Thanks in advance!
Dean
Something's not configured properly.  You may have to go into admin console and give ISY permission to communicate with the Portal.
From Wiki...
ISY Portal Account Setup
There are three steps for having ISY communicate through ISY Portal:
1. Creating an account on " ISY Portal if one does not exist (click on the Create new account link). If one already exists, simply login
2. Registering ISY with your account in ISY Portal using ISY's UUID (Help | About - also included in your invoice). To do this click on the Add ISY button and copy/paste the UUID from your invoice or order notification
3. Giving permission to ISY to communicate with ISY Portal
  • Login to the Admin Console
  • Click Configuration | Portals tab
  • You will see a request for access from your account in ISY Portal
  • Approve it
  • You are done!
Jon...
Thanks Jon, I had two errors: 1) I was trying to do this through Admin Console, rather than the portal URL; 2) ISY needed to reboot to get back online.  Now I hope to be able to figure out how to make functional ISY Recipe through IFTTT.
The Wiki has pretty good instructions for setting up the Event Name in the Portal and creating the IFTTT recipe.
Any other questions just post them back.
Jon...
