Scene Problem
My home irrigation system consists of an EZRain Irrigation Controller that is controlled by an ISY program.
I want to add an 8 button On/Off Keypad  to show which sprinklers are on and to be able to command them by pushing the appropriate button.
I created a Scene containing a button and the appropriate Irrigation Controller interface.  I can call up the Scene but nothing happens.
Any suggestions?
Do I need to use a Scene?
Would it be better to do this all by program?
All you are trying to do is manually control an irrigation zone from a keypad button?  Sounds like you have done everything correct to me, but make sure you added the KPL button as a "controller" of the scene.  I believe controllers show up as red in the scene listing.
It turns out that the problem was in the wire connecting the irrigation controller to the valve.  The wire came loose and fell out.
Thanks for the help.
