Can't Install IR Linc 2411T
I can't seem to link this device. Don't see anything in the forum and the Wiki is useless for this issue.
It's brand new.  Thanks.
I get:
If you run the Event Viewer in Level 3. What does it report when you try and add it?
You can use the copy to clipboard function and then post it here.
What firmware is in your ISY994i and does the UI version match the firmware version?
Edited by Brian H
Ok, I got it.  I found another post, apparently it does not link in the normal way, you link it by setting up the buttons, which puts a node in the tree, then you add the node to a scene.  Works well, but it is a very sloooow process.  I think I also may have held the remote key too long (I held it until the 2411T LED stopped flashing), because when I test it on a little TV I have, I turn on the scene, it turns on the TV and then turns it off again, so the sequence is too long.  Maybe you don't have to hold the remote key while learning until it stops flashing and beeps?  Need to play with it.
