Program To Turn Off and IOLinc At 0900 The Following Day
I am a bit embarrassed to seek help with what should be a simple program, but I am stuck. I have a scene managed by a KPL button. When that button is pressed it turns on an IOLinc. The IOLinc, when on, sends power to an irrigation controller which executes its irrigation program beginning at 0500 and running until approximately 0830. I would like to have a program that:
If the KPL button (or IOLinc) is On
Turn the KPL button (or IOLinc) Off at 0900 the following day
I can't figure out how to set the 0900 for the day following when the KPL button is pressed.
I would like for the KPL button to show as OFF following the program running.
This would safeguard against the pump staying On.
Use From ... To. Enter any From time that'll work for you.
