insteon and upb switch with elk m1 help
lurlette
i have a ELKM1PCSPIM hooked up to my m1,and i have a UPB light switch that controls a light over my step,so i have a rule setup in my m1 to turn on the light over the step when a motion detector detects motion,(the UPB switch shows  A1 in elk m1 lighting) and that`s working fine,Now i want to be able to control my other INSTEON switches through the elk m1,but when i import my insteon light file to my elk m1 the imported file goes to A1 also(a INSTEON LIGHT SWITSH), so now the rule is turning on the UPB switch and the INSTEON switch, because they all want to use A1 ,How can i change the insteon to be A6 or some other address in ELK M1?
I don`t know if this is the right place to post this,so please let me know if its ok or not. Thanks in Advance.
I am not certain how to answer your question specifically but those sound like X10 commands so look into changing one Insteons X10 and see if that does anything and if so you need to change them all or do something else.
Do you have a XEP and ISY module? This would be the better route to go then you can use all your sensors for Elk on the ISY side for programs etc. Including notifications. Just know the SSL connection to the XEP does not work so its unencrypted communication between them.
      37.6k
      376.2k
