June 9, 201610 yr I've setup programs to alert me when the Schlage locks are locked or unlocked via the keypad. Two questions that I can't figure out: 1) Can the alert tell me which user code was used to unlock the keypad? I can't find an obvious solution. 2) Is there anyway to rename the user code from User N to Bob or something like that? As always, thanks in advance.
June 9, 201610 yr Author Which Schlage lock? Schlage Connect Touchscreen Deadbolt with Alarm MODEL BE369 Is that enough information?
June 9, 201610 yr Author No to both. The BE469 will allow you to query specific users. Bummer - I don't suppose there is a way to upgrade the firmware?
June 9, 201610 yr Nope. Schlage doesn't even have interchangeable parts between different locks. For example, when I went from the BE369 to the BE469, I had to change the bolt, too.
