Fanlinc
So I am having trouble with my Fanlinc. I had it setup with a KPL. It was working fine then all of a sudden it would only go to medium. I deleted from the ISY, rediscovered it, I factory reset (before rediscovery). I have taken the KPL out of the equasion by removing all of the button scenes. So controlling through the ISY dashboard only - again only medium turns the fan on. Any other speed does not work. Anyone seen this or have any suggestions?
Edited by TheWabit
Can you adjust the speed at the fan itself? If so you may have a bad fanlinc. If not, the fan speed switch may be bad. You could check the voltage going to the fan from the fanlinc to see if it changes when you command it to different speeds.
Harv
