Should I Be Able to Change Temp from ISY Admin?
Sorry if this is a silly question, but am I supposed to be able to change the thermostat set points from the ISY admin?  I have Nodelink talking to Total Connect Confort, pulling set points and other data that my Wifi thermostat provides.  However, I cannot get any set point updates made from the admin to change anything in TCC / on the stat.
Nodelink updates setpoint changes made from the TCC iPhone app after a minute or two, which then updates in the ISY Admin.  I guess I am a little confused on exactly what functionality I am supposed to have via NodeLink + ISY.
Thanks in advance,
Jason
Yep, should be able to.
Enable verbose logging for the device in NodeLink and check for any errors in the log.
Thanks.  I noticed something interesting trying to look into this.  If I don't name the thermostat:
nodename: Honeywell
nickname: Thermostat
I get 404 when I click on the device.  It always names the device "Honeywell" in ISY Admin, no matter what nodename / nicknames I use.  So, it appears that if I don't match that with a nodename of Honeywell in NodeLink, I get 404 on the device link.  Naming it Honeywell, makes everyone happy.
Now, it appears that Javascript is not enabled...but I am not sure what browser it is using because I tried the three installed (IE, FF, Chrome) and I was able to log in and change things with no error messages.  Thoughts?  I am running on Server 2008 which is kind of a PITA with security type settings in the browser.
2016-06-27 16:01:18 - ISY NodeLink Server v0.5.4 started
2016-06-27 16:01:18 - Web config server started (http://192.168.10.80:8090)
2016-06-27 16:01:18 - ISY resolved to 192.168.10.250
2016-06-27 16:01:19 - ISY Error: Duplicate node names exist on the ISY (Powerlinc USB Modem - Server.)
2016-06-27 16:02:24 - TCC Login: <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<!--[if IE 8 ]>    <html class="ie8" xmlns="http://www.w3.org/1999/xhtml"><![endif]-->
<!--[if IE 9 ]>    <html class="ie9" xmlns="http://www.w3.org/1999/xhtml"><![endif]-->
<!--[if (gt IE 9)|!(IE)]><!-->
<html xmlns="http://www.w3.org/1999/xhtml">
<!--<![endif]-->
<head>
    <meta http-equiv="X-UA-Compatible" content="IE=edge" />
    <meta http-equiv="content-type" content="text/html; charset=UTF-8" />
    <title>THERMOSTAT Control</title>
    <!--[if IE]>
        <style>
            .page {
                    height: auto !important;
        </style>
    <![endif]-->
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/jquery.qtip.truehome.css"/>
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/jquery.ui.truhome.css"/>
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/Layout.css?v=2.0.49" />
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/Site.css?v=2.0.49" />
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/Buttons.css?v=2.0.49" />
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/EditorTemplates.css?v=2.0.49" />
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/ModalAjaxContentDialog.css?v=2.0.49" />
    <script type="text/javascript" src="/portal/Scripts/jquery-1.11.0.min.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.unobtrusive-ajax.min.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.validate.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.validate.unobtrusive.min.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery-ui-1.10.4.min.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.qtip.min.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.idletimer.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.idletimeout.js"></script>
    <script type="text/javascript" src="/portal/Scripts/Common/SessionTimeoutHandler.js?v=2.0.49"></script>
    <script type="text/javascript" src="/portal/Scripts/Common/ModalAjaxContentDialog.js?v=2.0.49"></script>
    <script type="text/javascript" src="/portal/Scripts/Common/CustomEvents.js?v=2.0.49"></script>
    <script type="text/javascript" src="/portal/Scripts/Common/EditorTemplates.js?v=2.0.49"></script>
    <script type="text/javascript" src="/portal/Scripts/Common/BrowserDetect.js?v=2.0.49"></script>
    <script type="text/javascript" src="/portal/Scripts/Common/Ajax.js?v=2.0.49"></script>
    <script type="text/javascript" src="/portal/Scripts/Common/IE.js?v=2.0.49"></script>
    <script type="text/javascript">
        var _unauthorizedAjaxRedirectTo = "/portal/";
    </script>
<meta http-equiv="Pragma" content="no-cache" />
<meta http-equiv="Expires" content="-1" />
<link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/Control.css?v=2.0.49" />
<script type="text/javascript" src="/portal/Scripts/Control/Control.js?v=2.0.49"></script>
<script type="text/javascript" src="/portal/Scripts/Control/Control.Model.js?v=2.0.49"></script>
<script type="text/javascript" src="/portal/Scripts/Control/Control.Res.js?v=2.0.49"></script>
<script type="text/javascript" src="/portal/Scripts/Control/Control.UI.js?v=2.0.49"></script>
<script type="text/javascript" src="/portal/Scripts/Control/Control.Urls.js?v=2.0.49"></script>
<script type="text/javascript" src="/portal/Scripts/Control/Control.Init.js?v=2.0.49"></script>
<script type="text/javascript" >
    $(document).ready(function()
        ///////////////////// pass model data to client-side logic /////////////////////
        Control.Model.set(Control.Model.Property.displayedUnits, 'F');
        Control.Model.set(Control.Model.Property.commercial, false);
        Control.Model.set(Control.Model.Property.communicationLost, false);
        Control.Model.set(Control.Model.Property.coolLowerSetpLimit, 50.0000);
        Control.Model.set(Control.Model.Property.coolNextPeriod, 88);
        Control.Model.set(Control.Model.Property.coolSetpoint, 75.0);
        Control.Model.set(Control.Model.Property.coolUpperSetptLimit, 99.0000);
        Control.Model.set(Control.Model.Property.deadband, 0.0000);
        Control.Model.set(Control.Model.Property.deviceID, 198615);
        Control.Model.set(Control.Model.Property.dispTemperature, 75.0000);
        Control.Model.set(Control.Model.Property.dispTemperatureAvailable, true);
        Control.Model.set(Control.Model.Property.dualSetpointStatus, false);
        Control.Model.set(Control.Model.Property.heatLowerSetptLimit, 40.0000);
        Control.Model.set(Control.Model.Property.heatNextPeriod, 88);
        Control.Model.set(Control.Model.Property.heatSetpoint, 67.0);
        Control.Model.set(Control.Model.Property.heatUpperSetptLimit, 90.0000);
        Control.Model.set(Control.Model.Property.holdUntilCapable, true);
        Control.Model.set(Control.Model.Property.indoorHumidity, 128.0000);
        Control.Model.set(Control.Model.Property.indoorHumiditySensorAvailable, false);
        Control.Model.set(Control.Model.Property.isInVacationHoldMode, false);
        Control.Model.set(Control.Model.Property.outdoorHumidity, 128.0000);
        Control.Model.set(Control.Model.Property.outdoorTemp, 128.0000);
        Control.Model.set(Control.Model.Property.schedCoolSp, 73.0000);
        Control.Model.set(Control.Model.Property.schedHeatSp, 67.0000);
        Control.Model.set(Control.Model.Property.scheduleCapable, true);
        Control.Model.set(Control.Model.Property.setpointChangeAllowed, true);
        Control.Model.set(Control.Model.Property.statusCool, 1);
        Control.Model.set(Control.Model.Property.statusHeat, 1);
        Control.Model.set(Control.Model.Property.switchAutoAllowed, false);
        Control.Model.set(Control.Model.Property.switchCoolAllowed, true);
        Control.Model.set(Control.Model.Property.switchEmergencyHeatAllowed, false);
        Control.Model.set(Control.Model.Property.switchHeatAllowed, true);
        Control.Model.set(Control.Model.Property.switchOffAllowed, true);
        Control.Model.set(Control.Model.Property.systemSwitchPosition, 3);
                Control.Model.set(Control.Model.Property.temporaryHoldUntilTime, 1320);
        Control.Model.set(Control.Model.Property.vacationHold, 0);
                Control.Model.set(Control.Model.Property.vacationHoldUntilTime, null);
        Control.Model.set(Control.Model.Property.fanMode, 0);
        Control.Model.set(Control.Model.Property.fanModeAutoAllowed, true);
        Control.Model.set(Control.Model.Property.fanModeOnAllowed, true);
        Control.Model.set(Control.Model.Property.fanModeCirculateAllowed, false);
        Control.Model.set(Control.Model.Property.fanModeFollowScheduleAllowed, false);
        Control.Model.set(Control.Model.Property.hasFan, true);
        Control.Model.set(Control.Model.Property.weatherPhrase, 'Sunny');
        if (42 != 0) {
            Control.Model.set(Control.Model.Property.weatherHumidity, '42');
        } else {
            Control.Model.set(Control.Model.Property.weatherHumidity, formatHumidity(0, false));
        if (94 != 0) {
            Control.Model.set(Control.Model.Property.weatherTemperature, '94');
        } else {
            Control.Model.set(Control.Model.Property.weatherTemperature, formatTemperature(0, false));
        Control.Model.set(Control.Model.Property.weatherHasStation, false);
        Control.Model.set(Control.Model.Property.weatherIcon, 1);
        Control.Model.set(Control.Model.Property.canControlHumidification, false);
        Control.Model.clearPropertyUpdates();
        ///////////////////// pass resources to client-side logic /////////////////////
        Control.Res.F1DataSessionStarted = "Data Session started successfully.";
        Control.Res.F1DataSessionFailed = "Data Session initialization failed.";
        Control.Res.F1DataSessionOpen = "Data Session is open.";
        Control.Res.F1StatusCommunicationLost = "Communication with your thermostat has been lost.";
        Control.Res.F1DataSessionTimeout = "Data Session is no longer open.";
        Control.Res.FollowingSchedule = "Following Schedule";
        Control.Res.Help = "Help";
        Control.Res.FollowingScheduleInRecovery = "Following Schedule in Recovery";
        Control.Res.FanHelpTextOnMode = "<p><b>On</b>: Fan is always on.</p>";
        Control.Res.FanHelpTextAutoMode = "<p><b>Auto</b>: Fan runs only when the heating or cooling system is on.</p>";
        Control.Res.FanHelpTextCirculateMode = "<p><b>Circulate</b>: Fan runs randomly, about 35% of the time.</p>";
        Control.Res.FanHelpTextFollowScheduleMode = "<p><b>Follow Schedule</b>: Fan controlled by the program schedule.</p>";
        Control.Res.FanHelpText = "<p>After you select your desired setting, press <b>Submit</b> to save your changes.</p>";
        Control.Res.LocationCodeChange = "Please contact the account owner to have the location code changed.";
        Control.Res.UnsavedChanges = "You have unsaved changes. Click Submit in the lower right corner of control panel.";
        ///////////////////// pass urls to client-side logic /////////////////////
        Control.Urls.refreshAlerts = '/portal/Device/Alerts?locationId=175319&deviceId=198615';
        Control.Urls.refreshDataSession = '/portal/Device/CheckDataSession/198615';
        Control.Urls.locationDeviceIndex = '/portal/175319/Zones';
        Control.Urls.submitControlScreenChanges = '/portal/Device/SubmitControlScreenChanges';
        Control.Urls.forecasts = '/portal/Device/Forecasts?locationId=175319&units=Fahrenheit';
        Control.Urls.humidificationMenu = '/portal/Device/Menu/198615/tab2';
        ///////////////////// initialize client-side logic /////////////////////
        Control.Init();
</script>
        var _gaq = _gaq || [];
        _gaq.push(['_setAccount', 'UA-33271749-1']);
        _gaq.push(['_setDomainName', 'alarmnet.com']);
        _gaq.push(['_trackPageview']);
        (function ()
            var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true;
            ga.src = ('https:' == document.location.protocol ? 'https://ssl': 'http://www') + '.google-analytics.com/ga.js';
            var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s);
        var noCookiesErrorMessage = 'This site will not operate without Cookies enabled.   Refer to the FAQs tab on this site to learn about enabling Cookies for your browser.';
    </script>
</head>
<body>
    <div id="_verticalGradientBackground">
    </div>
    <div id="_contentWrapper">
        <div id="_leftBackground">
        </div>
        <div id="_content">
            <div id="header">
                <div id="header-top">
                    <ul id="toplinks">
                        <li><a href="https://www.honeywell.com"target="_blank">Honeywell.com</a></li>
                        <li><a href="https://yourhome.honeywell.com/"target="_blank">Home Comfort & Energy Systems</a></li>
                    </ul>
                </div>
                <div id="logo">
                    <a href="/portal/">Honeywell - My Total Connect Comfort<span></span></a>
                </div>
            </div>
            <div id="menucontainer">
                <ul id="menu">
                    <li class="menulink"><a href="https://yourhome.honeywell.com/home/Applications/ContactUs.aspx"
                        target="_blank">
                        Contact Us
                    </a></li>
                    <li class="menudivider"></li>
                        <a href="/portal/Home/FAQs">FAQs</a>
                    </li>
                            <a href="/portal/MyAccount">My Account</a>
                        </li>
                            <a href="/portal/">Control Center</a>
                        </li>
                            <a href="/portal/Account/LogOff">Sign Out</a>
                        </li>
                        <li id="greeting">
                            Welcome
                            <b>Jason</b> </li>
                </ul>
            </div>
            <div id="red-grey-line">
            </div>
            <div id="breadcrumb">
    <div class="crumbs">
    </div>
    <div class="breadcrumb-arrow"></div>
        <a href="/portal/Locations">My Locations</a>
    </div>
        <a href="/portal/175319/Zones">Thermostat(s) in Highland</a>
    </div>
        THERMOSTAT Control
    </div>
            </div>
            <div id="main">
                <noscript>
                    <div id="NoJavaScript">This site will not operate without JavaScript enabled.  Refer to the FAQs tab on this site to learn about enabling JavaScript for your browser.</div>
                </noscript>
                <div id="NoCookies">
                </div>
                <div id="unsupportedbrowser">
                </div>
                <div id="mainContent">
<div class="TitleAndAlerts">
    <div id="ControlScreenHeader">
        <h1 id="ZoneName">THERMOSTAT Control</h1>
    </div>
    <div id="AlertsPlaceHolder">
</div>
</div>
<form id="ControlForm" action="">
    <div id="ControlScreen" class="WithOutdoor WithFan">
        <div id="TempDisplays">
            <div id="IndoorDisplay">
                <div class="IndoorTemp">
                    <div class="IndoorTempHdr">Indoor</div>
                    <div class="IndoorTempDisplay">
                        <div class="DisplayValue">75</div><span class="NoBold">°</span>
                    </div>
                </div>
                <div class="IndoorHumidity " style="display: none">
                    <div class="IndoorHumidityDisplay">
                        <div class="DisplayValue">128</div><sup class="IndoorHumidityPercent">%</sup>
                    </div>
                    <div class="IndoorHumidityHdr">Humidity</div>
                </div>
            </div>
            <div id="OutdoorDisplay">
                <div class="OutdoorDisplayHdr">Outdoor</div>
                <div class="OutdoorTempDisplay">
                    <div class="DisplayValue">--</div><span class="NoBold">°</span>
                </div>
                <div class="OutdoorHumidity">
                    <div class="OutdoorHumidityDisplay">
                        <div class="DisplayValue">--</div><sup class="OutdoorHumidityPercent">%</sup>
                    </div>
                    <div class="OutdoorHumidityHdr">Humidity</div>
                </div>
                <img id="CurrentWeatherIcon" alt="Sunny" title="Sunny" class="WeatherIcon" src="/portal/Images/Icons/Weather/1_sunny%402x.png?v=2.0.49" style="display: inline-block" />
                <div class="FiveDayForecastInfo">
                    <div id="FiveDayForecastBtn" class="FiveDayForecastBtn" style="display: inline-block">5-Day Forecast</div>
                    <a href="/portal/Location/Edit/175319" id="InvalidZipCodeLink" style="display: none">Invalid Zip Code</a>
                    <div id="LocationCodeChange" title="Help" style="display: none">Invalid Zip Code</div>
                    <div id="LocationCodeChangeHelpBox" style="display: none">Please contact the account owner to have the location code changed.</div>
                </div>
            </div>
        </div>
        <div id="SystemButtons">
            <div class="SystemButtonsHdr">System</div>
            <div id="HeatBtn" class="unselectable SystemButton" style="">
                <div class="SystemText">HEAT</div>
            </div>
            <div id="CoolBtn" class="unselectable SystemButton SystemButtonOn" style="">
                <div class="SystemText">COOL</div>
            </div>
            <div id="AutoBtn" class="unselectable SystemButton" style="display: none">
                <div class="SystemText">Auto</div>
            </div>
            <div id="OffBtn" class="unselectable SystemButton" style="">
                <div class="SystemText">OFF</div>
            </div>
            <div id="EMHeatBtn" class="unselectable SystemButton" style="display: none">
                <div class="SystemText">EMHEAT</div>
            </div>
        </div>
        <div id="AutoModeTempControls" style="display: none">
            <div id="AutoHeatSetpt">
                <div class="SetPtContainer">
                    <div class="CurrSetptHdr">Heat Setpoint</div>
                    <div class="CurrentSetpt"><div class="DisplayValue">67</div><span class="NoBold">°</span></div>
                </div>
                <div class="SetPtButtons" style="">
                    <div id="AutoModeHeatUpBtn" class="UpBtn unselectable"> </div>
                    <div id="AutoModeHeatDownBtn" class="DownBtn unselectable"> </div>
                </div>
            </div>
            <div id="AutoCoolSetpt">
                    <div class="CurrSetptHdr">Cool Setpoint</div>
                    <div class="CurrentSetpt"><div class="DisplayValue">75</div><span class="NoBold">°</span></div>
                </div>
                    <div id="AutoModeCoolUpBtn" class="UpBtn unselectable"> </div>
                    <div id="AutoModeCoolDownBtn" class="DownBtn unselectable"> </div>
                </div>
            </div>
        </div>
        <div id="NonAutoModeTempControls" style="">
            <div id="NonAutoHeatSetpt" style="display: none">
                    <div class="CurrSetptHdr">Set To</div>
                </div>
                    <div id="NonAutoModeHeatUpBtn" class="UpBtn unselectable"> </div>
                    <div id="NonAutoModeHeatDownBtn" class="DownBtn unselectable"> </div>
                </div>
            </div>
            <div id="NonAutoCoolSetpt" style="">
                </div>
                    <div id="NonAutoModeCoolUpBtn" class="UpBtn unselectable"> </div>
                    <div id="NonAutoModeCoolDownBtn" class="DownBtn unselectable"> </div>
                </div>
            </div>
        </div>
        <div id="ScheduledStatus" style="display: none">
            <div id="ScheduledStatusHdr">
                Following Schedule
            </div>
        </div>
        <div id="DemandResponseEventStatus" style="display: none">
            <div id="DemandResponseEventStatusHdr">
                <a href="javascript:void(0);" onclick="Control.displayOptOutPopup();">Energy Saving Event</a>
            </div>
        </div>
        <div id="TemporaryStatus" style="">
            <div id="HoldUntilTime">
                Hold Until
                <div class="DisplayValue"></div>
            </div>
            <div id="HoldUntilOptionsBtn" class="unselectable">Press for Options</div>
        </div>
        <div id="TemporaryStatusOptions" style="display: none">
            <div id="TemporaryHoldOptionsHoldUntilContainer">
                <div class="HoldUntilTimeContainer">
                    <div class="HoldUntilTimeHdr">Hold Until </div>
                    <div class="HoldUntilTimeValue"></div>
                </div>
                <div class="HoldUntilButtonsContainer">
                    <div class="HoldUntilUpBtn unselectable"> </div>
                    <div class="HoldUntilDownBtn unselectable"> </div>
                </div>
            </div>
            <div id="TemporaryStatusOptionButtons">
                <div class="SwitchToPermanentBtn unselectable" style="">Switch to Permanent Hold</div>
                <div class="CancelHoldBtn unselectable" style="">Cancel Hold</div>
            </div>
        </div>
        <div id="PermanentStatus" style="display: none">
            <div id="PermanentStatusHdr">Permanent Hold</div>
            <div id="PermanentStatusOptionsBtn" class="unselectable">Press for Options</div>
        </div>
        <div id="PermanentStatusOptions" style="display: none">
            <div id="PermanentStatusOptionsHdr">Permanent Hold</div>
            <div id="PermanentStatusOptionButtons">
                <div id="SwitchToTemporaryHoldBtn" class="unselectable">Switch to Temporary Hold</div>
                <div class="CancelHoldBtn unselectable">Cancel Hold</div>
            </div>
        </div>
        <div id="SouthernAwayStatus" style="display: none">
            <div id="SouthernAwayStatusHdr">Dehumidification Away Mode is Active</div>
            <div id="SouthernAwayHelpButton" class="unselectable">Help</div>
        </div>
        <div id="SouthernAwayHelpBox">Dehumidification Away Mode is a pre-programmed option that controls humidity while your house is vacant during the summer, to help protect your home and possessions while you are away. Please contact the contractor who installed your system if you would like to change these settings or learn more about them.</div>
        <div id="VacationStatus" style="display: none">
            <div id="VacationHoldHdr">Away until</div>
            <div id="VacationHold"></div>
            <div id="VacationHoldHelpButton" class="unselectable">Help</div>
        </div>
        <div id="VacationHoldHelpBox">When the thermostat is in Vacation Mode the settings can not be edited remotely and can only be changed locally at the thermostat.</div>
        <div id="OffStatus" style="display: none">
            <div id="OffStatusHdr">Device is Off</div>
        </div>
        <div id="MenuOptions">
            <div class="MenuOptionsButton unselectable">
                <a class="unselectable" href="/portal/Device/Menu/198615?ReturnTo=ControlScreen198615">Menu</a>
            </div>
        </div>
        <div id="FanSystemButtons" style="">
            <div id="FanSystemButtonsHdr">Fan</div>
            <div id="FanOnBtn" class="unselectable FanSystemButton" style="">
                <div class="SystemText">On</div>
            </div>
            <div id="FanAutoBtn" class="unselectable FanSystemButton FanSystemButtonOn" style="">
            </div>
            <div id="FanCirculateBtn" class="unselectable FanSystemButton" style="display: none">
                <div class="SystemText">Circulate</div>
            </div>
            <div id="FanFollowScheduleBtn" class="unselectable FanSystemButton" style="display: none">
                <div class="SystemText">Follow Schedule</div>
            </div>
            <div id="FanHelpBtn" class="helpButton unselectable" title="Help" style=""></div>
        </div>
        <div id="EquipmentStatus">
            <div id="eqStatusFanOn" class="hidden">
            <div class="equipStatusIcon fanOnIcon"></div>
            <div class="equipStatusText">Fan is on</div>
            </div>
            <div id="eqStatusHeating" class="hidden">
                <div class="equipStatusIcon heatIcon"></div>
                <div class="equipStatusText">Heat is on</div>
            </div>
            <div id="eqStatusCooling" class="">
                <div class="equipStatusIcon coolIcon"></div>
                <div class="equipStatusText">Cool is on</div>
            </div>
        </div>
        <div id="DisabledSubmitBtnDiv">
            <div id="DisabledSubmitBtn" class="unselectable">Submit</div>
        </div>
        <div id="SubmitBtnDiv">
            <div id="SubmitBtn" class="unselectable">Submit</div>
        </div>
        <div id="start-session-status"> </div>
    </div>
    <div id="FiveDayForecast" class="FiveDayForecast" style="display: none">
        <a href="" tabindex="1"></a>
        <div class="header">
                <h2>5-Day Forecast for <a href="/portal/Location/Edit/175319">78703</a></h2>
        </div>
        <div class="LoadingDiv" style="display: none">
            <div>
                <img src="/portal/Images/Icons/icon_activity_indicator_animation.gif?v=2.0.49" alt="Loading..." title="Loading..." />
            </div>
            <div style="position: relative; left: 5px;">
                Loading...
            </div>
        </div>
        <div class="ContentDiv" style="display: none">
        </div>
        <div class="buttonarea">
            <div class="button red" id="FiveDayForecastDoneBtn"><span class="left unselectable">Close</span><span class="right"></span></div>
        </div>
    </div>
</form>
    <div class="buttonwrapper">
        <div class="button back"><a href="/portal/175319/Zones">Back</a><span class="right"></span></div>
    </div>
</div>
                </div>
            </div>
            <div id="gatewaylog">
            </div>
            <div id="_push">
            </div>
            <div id="_footer">
                <div>Version 2.0.49 - April 26, 2016</div>
                <ul class="left" style="width: 700px;margin-top: 5px;">
                    <li class="rightborder"><a href="/portal/Home/TermsAndConditions">Privacy Statement and End User License Agreement</a></li>
                    <li class="rightborder"><a href="/portal/Home/TermsConditions">Terms & Conditions</a></li>
                    <li class="rightborder"><a href="http://www.mytotalconnectcomfort.com/Account/ResetLocalisationCulture">GlobalSite</a></li>
                    <li class="rightborder"><a href="/portal/Home/Feedback">Feedback</a></li>
                    <li><br/>  <a href="https://honeywell.com/Pages/Home.aspx"target="_blank">© 2016 Honeywell International Inc.</a></li>
                </ul>
                <ul id="CultureControl">
<li class="rightborder"><a class="culture-link" data-ajax="false" href="/portal/Account/ChangeCulture?lang=en-US&returnUrl=%2Fportal%2FDevice%2FControl%2F198615" style="text-decoration: underline;">English</a> </li>
<li><a class="culture-link" data-ajax="false" href="/portal/Account/ChangeCulture?lang=fr-CA&returnUrl=%2Fportal%2FDevice%2FControl%2F198615" style="">Français</a></li>
                </ul>
            </div>
        </div>
        <div id="_rightBackground">
        </div>
    </div>
        <div id="dialog" style="display: none">
            <div class="warning"></div>
            <ul>
                <li class="header">Your session is about to expire.</li>
                <li>You will be logged off in <span id='dialog-countdown' style='font-weight:bold'></span> seconds.</li>
                <li>Do you want to continue your session?</li>
            </ul>
        </div>
            var sessionTimeoutHandler = new SessionTimeoutHandler(
                "#dialog",
                "#dialog-countdown",
                "Yes",
                "No",
                '/portal/Account/LogOff',
                '/portal/Account/KeepAlive',
                '/portal/Account/Timeout'
            sessionTimeoutHandler.Initialize();
        </script>
    <script type="text/javascript" language="javascript">
        $(function ()
            var isMobileDevice = false;
            if (BrowserDetect.browser == "Explorer" && parseFloat(BrowserDetect.version) < 8)
                $("#unsupportedbrowser").html('The web browser you are using is not supported.  A supported browser is required to use Total Connect Comfort.  The most recent versions of Chrome, Safari, Firefox and Internet Explorer may be used.  Update or download one of these browsers to use Total Connect Comfort.');
    </script>
</body>
</html>
 [honeywell]
2016-06-27 16:02:25 - TCC Data: <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<!--<![endif]-->
<head>
    <!--[if IE]>
        <style>
            .page {
        </style>
    <![endif]-->
    </script>
        if (42 != 0) {
        } else {
        if (94 != 0) {
        } else {
        Control.Init();
</script>
        (function ()
    </script>
</head>
<body>
    </div>
        </div>
        <div id="_content">
            <div id="header">
                    <ul id="toplinks">
                    </ul>
                </div>
                <div id="logo">
                </div>
            </div>
                <ul id="menu">
                        target="_blank">
                        Contact Us
                    </a></li>
                    </li>
                        </li>
                        </li>
                        </li>
                        <li id="greeting">
                            Welcome
                            <b>Jason</b> </li>
                </ul>
            </div>
            </div>
    </div>
    </div>
    </div>
        THERMOSTAT Control
    </div>
            </div>
            <div id="main">
                <noscript>
                </noscript>
                </div>
                </div>
here is the 2nd part
    </div>
</div>
</div>
                    </div>
                </div>
                    </div>
                </div>
            </div>
                </div>
                    </div>
                </div>
                </div>
            </div>
        </div>
            </div>
            </div>
            </div>
            </div>
            </div>
        </div>
                </div>
                </div>
            </div>
                </div>
                </div>
            </div>
        </div>
                </div>
                </div>
            </div>
                </div>
                </div>
            </div>
        </div>
                Following Schedule
            </div>
        </div>
            </div>
        </div>
                Hold Until
            </div>
        </div>
                </div>
                </div>
            </div>
            </div>
        </div>
        </div>
            </div>
        </div>
        </div>
        </div>
        </div>
            </div>
        </div>
            </div>
            </div>
            </div>
            </div>
        </div>
            </div>
            </div>
            </div>
        </div>
        </div>
        </div>
    </div>
        </div>
            <div>
            </div>
                Loading...
            </div>
        </div>
        </div>
        </div>
    </div>
</form>
    </div>
</div>
                </div>
            </div>
            </div>
            <div id="_push">
            </div>
            <div id="_footer">
                </ul>
<li class="rightborder"><a class="culture-link" data-ajax="false" href="/portal/Account/ChangeCulture?lang=en-US&returnUrl=%2Fportal%2FDevice%2FControl%2F198615%3Fpage%3D1" style="text-decoration: underline;">English</a> </li>
<li><a class="culture-link" data-ajax="false" href="/portal/Account/ChangeCulture?lang=fr-CA&returnUrl=%2Fportal%2FDevice%2FControl%2F198615%3Fpage%3D1" style="">Français</a></li>
                </ul>
            </div>
        </div>
        </div>
    </div>
            <ul>
            </ul>
        </div>
                "#dialog",
                "Yes",
                "No",
        </script>
        $(function ()
    </script>
</body>
</html>
 [honeywell]
Wait till the next release and put it back on your Pi.  Server is always a PITA with browser security and permissions.
The data looks fine.  I don't see anywhere in there where you tried to set the temperature from the ISY (fail or success).
I can't reproduce what your describing with the nickname, these do not have to match.  I just created a new device and named it Thermostat without any issue.  Every TCC stat will show up in the ISY as Honeywell, you can rename it any way you want.
