check light status before flash, flash, then put them back at the same status
Hi gang :-)
Sorry for my imperfect english :-)
I have a waterleak sensor and i would like it make my light in my house are flashing 3 times, wait 2 minutes, flash again, etc, as long as the waterleak sensor is still on (recognize water).
I would like also it check my light status before starting to flash and put them back as what they are before starting to flash when the leak sensor is going to off, mean no water problem anymore
For example, before my water problem appear my living room light was on at 40%, and my kitchen light was off so i would like it flash as describe above and as soon as the water problem is finish,put it back  at the same level as what they were.
This is the part that i don't know how to do. Is there an easy way to to that ?
Thank you for your genius :-)
Dj BoomBoX
AFAIK, version 5 (Alpha) is the only version that allows storing the current On-level of a device.Currently, I use scenes to set On-levels, so if I want the level to return, I simply use whatever program to turn the scene on.
IMO, if I had a leak, setting the devices to their On-levels would not be a big concern. Tending to the leak is primary B)
