Eliminate "light" option w/ Insteon Fan Linc
Installed an Insteon Fan Linc (2475F) control module and I can't figure out how to hide the "light" option from the ISY 994i module.
I can't delete it as the entire module controlling the fan will disappear as well
appreciate any info you might have
Chuck
I don't believe you can hide it. As it is part of the modules features.
Are you only using the fan output on the FanLinc and don't want the lamp output showing in the Administrative Console?
Edited by Brian H
Like Brian H, I am unaware of any method one can use to eliminate a device or node from the ISY admin panel.  The method I use is to name it something like "fanlinc light (unused)" and move it to a folder of unused devices.
Also, prefix it with ~ and it will be suppressed from the web interface.
