Portal maintenance - October 2 - 4am-5am Pacific ×
How to delete a device?
dmazan
How do I delete a device?  What I really want to do is only write the ISY-specific links to the device, ignoring any old, probably dead links.  I could have done that when I added the device, if I had picked that option.  But now that I added the device, keeping existing links, how do I get rid of the non-ISY links?  If I could delete the device, I could re-add it and select "remove old links".  But I can't seem to delete a device once it's there.
Restore device should clear any links the ISY doesn't know about. A device cannot be deleted if it's in a folder. In that case, remove it from the folder first, then delete it. Right click for a bunch of options.
Figured out that you have to remove the device from a folder to delete it.  That's odd.
Unfortunately, since I added the device checking "Add Devices Found In Links And Keep Existing Links" ISY does know about the links and happily adds them back on restore.  But now that I can delete the device I can simply re-add it checking "Remove Existing Links".
