Dual on/off outlet 2663-222
Jimbo.Automates
I just noticed that my dual on/off outlet only shows the top outlet in Agave? I know it used to show the bottom because I have one showing on my home screen, but none of the bottoms show up anymore?
Sent from my Nexus 6P using Tapatalk
I know what this is.  I made a few adjustments to the internal searching so it must be ignoring the second node.  I'll get this corrected and merged.
  • 5 months later...
I searched the forum but could not find what I needed.  I am looking for instructions on setting up a new 2663-222.  The ISY does not see the device, there is no Address label.  The outlet is located about 70 feet from the ISY Hub.
Once you have it installed.  On Agave navigate to "Things" -> "Switches / Dimmers"  and press the  (+) Icon.  It will take you through starting up the  node detection process or manually adding the new device.  You can also start this "Auto Linking" process from the ISY.
Once autolinking is running, press the "set" button on the 2663-222 for about 5 secs.  The ISY will detect it and auto install it.  Next stop the process and the device should be in your devices list.  You can now go rename it.
If you have further questions, go ahead and ask.
James, the ISY dos not find the switch during Auto Linking.
This is the Agave Android app subforum, you'll get better response in the insteon subforum ☺️
Sent from my Pixel C using Tapatalk
