Chamerlain MyQ Bypass
I recently purchased 2 new garagedoor openers after a failure.  The new garagedoors were the chamberlain whisper drives with myQ.  I neglected to read up on the interface and it turns out, as I have noticed quite a bit on the forums that there is no way to communicate my IOLincs directly into the opener itself.  So.....
I looked around and found some information about them and wired my IOLinc directly into my opener remote.  I have put up a tutorial up here: http://www.agaveha.com/documentation/chamberlain-myq-bypass/
I've done this same thing with 2 garage doors but used the lcd wall control that was provided with opener.
Sent from my SM-G920V using Tapatalk
I had the same problem with my two new Craftsman; I posted a video on YouTube doing exactly this with Insteon's hub, now on ISY - both work just fine... https://youtu.be/NBCdo0kANuM
It is an easy work around with these new multi-function wall remotes.
