Help with program for DSC Alarm
Need help writing a program for my DSC Alarm.  My intention with this program is that it will notify me every hour if the DSC alarm status is not in an Armed Away or Armed Stay status.  Below is what I have attempted. Not sure how to tell the isy to send a message every hour.
DSC Alarm Monitor - [iD 0046][Parent 00A3]
        On Mon, Tue, Wed, Thu, Fri
        From     9:00:00AM
        To       9:00:00AM (next day)
    And 'DSC Alarm / Partition 1' Status is Disarmed
     Or 'DSC Alarm / Partition 1' Status is Entry Delay
     Or 'DSC Alarm / Partition 1' Status is Exit Delay
        Send Notification to 'Jack Only' content 'Security System Not Armed'
        Send Notification to 'Jack Only' content 'Security System Armed'
Edited by ldrinc
Do you want to be notified at the top of every hour?   Or every 60 min from the time the state changes?
        'Alarm / Partition 1' Status is Disarmed
        Repeat Every  60 minutes
You'd then set it to run at startup.   If the alarm never changes from disarmed, you will get a notification every 60 min (from whenever ISY boots) telling you it is not armed.   The moment it arms, you will get a text, then a text every 60 min from that point.
If you want to be notified at the top of every hour what the status is, that would be a a different program.
Thanks much!  Every 60 mins will be ok.  However, if I where to be notified at the top of every hour.  How would I write something like that in a program?
if you wanted it at the top of every hour, I'd use 2 programs.
Program1 is disabled.
Program2 runs every hour
New Program - [ID 00DC][Parent 0001]
        Time is  1:00:00AM
     Or Time is  2:00:00AM
     Or Time is  3:00:00AM
     Or Time is 12:00:00AM
        Run Program 'Program1' (If)
Since i think you are running 5.x, if you have NodeLink and ISYData running, an easier Program2 would be:
        'ISY Data' Minutes is 0
        Run Program 'Arm (Away)' (If)
I am running 5.xx however I don't have ISYData yet.  Still looking to understand its features and benefits.  I will consider if/when I decide to run it.
Thanks again for your help.  Much appreciated.
