Zwave - Insteon intergration via ISY
If I install the Zwave module in my ISY will it enable the intergration with my installed Insteon hardware. So if a Zwave event happened it could trigger an Insteon event etc.
Yes, it can. Once you have Insteon and Zwave devices installed on your ISY994ZW, then these will "talk" to each other.
Works both ways. I have an insteon motion detector that I use in the garage to tell the ISY to turn on my overhead lights that are on a Zwave switch.
The integration is not complete. You'll have to use programs, not scenes if you want to integrate both protocols. I don't know if it's possible to use only scenes in Alpha Release 5+.
That's great.. Thanks all for your input, scene intergration would be nice but program control will meet my needs for now.
