keypad button in toggle-off to initiate a progam
guys,
sounds very simple, but I cant figure that one out.
I have a "all off" button on a keypad that turns all the lights off. button is in toggle-off mode.  works great.
now I want that "all off" button to also turn the thermostat fans to "auto"
how do I do that?
if I add it the the scene, I need to set cool VS heat, set temperature and fans too. (all 3) when I only want to change the fan to auto.
if I try to do a program that is triggered by the "all off" button, it does not work. I believe this is due to the toggle-off mode of the button. so the button never really get "on" so the program never trigger.
I tried:
if status "keypad/allOff" is responding  "does not work
if status "keypad/allOff" is off      "does not work
if status "keypad/allOff" is 100%         "does not work
any idea how to get my fans to auto when I press a button in toggle-off mode?
thanks
Status requires that the state of the controller changes. If the button is non-toggle off, then its stale never changes. Use Control and Off.
  • 3 weeks later...
