Frequency that Z-Wave operates
According to Wikipedia Z-Wave operates at
https://en.wikipedia.org/wiki/Z-Wave
908.42 MHz in the U.S. and Canada
However according to the Insteon Technology page
http://www.insteon.com/technology/
915 MHz
My main question is if you have too many Z-Wave and Insteon devices if they will interfere.
Has anybody experienced interference between Insteon and Z-Wave?
Insteon is actually 914.975MHz. The two frequencies are so far apart you can put New Jersey between them.
Best regards,
Gary Funk
Edited by GaryFunk
There is a whole lot of radio theory and low level protocol knowledge needed for a technical answer to the question. But no, the two solutions will not interfere with each other...
In the US/Canada, zwave occupies three frequency bands:
908.42 Mhz / 9.6kbs -- old devices
908.40 Mhz /40kbs  -- newer device plus the legacy above
916.00 MHz/100kbs -- "gen5" devices plus two bands above
Even with the gen5 frequency band, there's enough separation from Insteon. There may be other RF sources of interference, though.  One never knows without a spectrum analyzer.
Edited by vjk
For good measure, don't put your dual-band PLM and your ISY an inch apart from each other!
By same argument, perhaps avoid Z-Wave and Insteon dual-band in the same electrical box.
Enough power, and little enough separation, and any signal at any frequency can theoretically saturate a receiver, as no receiver has infinite selectivity.
Otherwise, that's plenty of separation.
I'd be more concerned with what ELSE might be on closer frequencies (or same frequency) as each.
- Portable phones
- wireless alarm systems
- leak detector systems (yes, my building has some kind of wireless leak detectors with proprietary system, company apparently out of business...)
- etc. etc. etc.
Edited by jtara92101
I have Z-Wave and Insteon devices in the same box in several locations. Both types of devices function flawlessly--each and every time. That includes program triggers as well as scenes. Echo, too.
