Programs don't execute unless I Query the device node?
I have a few simple dim-at-sunset/brighten-at-sunrise programs and have been trying to debug them.   Originally I was using a folder with sunrise scheduling, but it was hard to debug.  So instead I set a state variable to control "brightening", "dimming", and "normal" state and have folders keying off those state variables.
What I noticed: the folder status (set by the variable in response to schedule) is correct, but the program status (set by the devices) is not.  If I Query the devices involved, then suddenly all the programs run and the system behaves as expected.
Why wouldn't the device states be accurate?  Is this indicative of a communication problem?
For reference, here's a snippet of the programs I'm using:
2. Start Brightening at Sunrise - [iD 0010][Parent 0022]
        Time is Sunrise
     Or Time is Sunrise +  1 hour
     Or Time is Sunrise +  2 hours
        $Kitchen_Light_State  = 2
I have a "Brightening State" folder:
2. Brightening - [iD 000D][Parent 0022]
Folder Conditions for '2. Brightening'
        $Kitchen_Light_State is 2
In the folder, I have a variety of programs like this:
Brighten KL if on - [iD 0043][Parent 000D]
        Status  'Kitchen Dimmer - Entry Master' is not Off
        Set Scene 'Kitchen Main Lights / Kitchen Mains Slow Bright' On
...and a "done" program:
Done if lights are bright or off - [iD 000F][Parent 000D]
             Status  'Kitchen Ceiling Fan-Light' is Off
          Or Status  'Kitchen Ceiling Fan-Light' is 100%
    And (
             Status  'Kitchen Dimmer - Entry Master' is 100%
          Or Status  'Kitchen Dimmer - Entry Master' is Off
        Wait  5 seconds
        $Kitchen_Light_State  = 0
Yes, this strikes me as a comm problem. Watch the ISY status of a given device and see if it changes as you toggle it on/off. If not, I suspect you have the answer to your question.
If the status change of 'not off' happens while the folder is disabled the program won't fire. Then it needs another trigger (change in status) to reevaluate the program.
