Zooz ZSE40 Multisensor
http://www.getzooz.com/zooz-zse40-4-in-1-sensor.html
Hey Team!
I added this multi-sensor to my ISY and thinks have been working fine. After a few days, I went ahead and try to right some programs around it and noticed motion, temperature and humidity were updating fine, but luminance was not. I deicded to reboot the ISY and now the device type shows no input data what-so-ever, it's almost like the device type changed. Short of removing and re-adding, I'm not sure what to do.
I tried pulling some diagnostic information and I saw this
] ZW018_1 uid=18 type=4.7.1 mid=265 tid=8225 pid=8449 model=0
]    -  x5E  V0  ZWAVEPLUS_INFO
]    -  x98  V0  SECURITY
]    -  x86  V0  VERSION
]    -  x72  V2  MANUFACTURER_SPECIFIC
]    -  x5A  V0  DEVICE_RESET_LOCALLY
]    -  x85  V2  ASSOCIATION
]    -  x59  V0  ASSOCIATION_GRP_INFO
]    -  x73  V0  POWERLEVEL
]    -  x80  V0  BATTERY
]    -  x71  V4  NOTIFICATION
]    -  x31  V7  SENSOR_MULTILEVEL
]    -  x70  V1  CONFIGURATION
]    -  x84  V2  WAKE_UP
]    -  x7A  V2  FIRMWARE_UPDATE_MD
]   sensorType=  1  scaleMask=  3  defScale=1
]   sensorType=  3  scaleMask=  1  defScale=0
]   sensorType=  5  scaleMask=  1  defScale=0
] Node  18 - MBR Bath Multsensor Battery has the following neighbors
]    -          - Node   1 - [This ISY]
]    - Repeater - Node   3 - Dining On-Off Power Switch
]    - Repeater - Node   4 - Living Room On-Off Switch
]    - Repeater - Node   5 - Foyer On-Off Power Switch
]    - Repeater - Node   6 - TV Room On-Off Power Switch
]    - Repeater - Node   9 - ZW 009 On-Off Power Switch
]    - Repeater - Node  10 - ZW 010 On-Off Power Switch
]    - Repeater - Node  11 - ZW 011 On-Off Power Switch
] Node  18 - MBR Bath Multsensor Battery cannot retrieve association groups
]    -  x98  V0  SECURITY
]    -  x86  V0  VERSION
]    -  x80  V0  BATTERY
]    -  x84  V2  WAKE_UP
Edited by cyberk
sigh, I rebooted ISY again and now counters are back...still having issues with updates though
Edited by cyberk
Firstly, when you boot the ISY, battery powered devices will typically not show status until the device reports status because they cannot be queried while they are asleep.
Next, if you read the manual which you linked to, you will see that there are parameters listed that allow you to adjust their values at which they will report status.
Take Lumins for example, parameter 4 specifies how much the light level has to change before the light level is reported. It is likely that the setting is set high enough that you haven't experienced enough of a light level change to trigger a report being sent to the ISY.
