GoControl (Nortek) - Z-Wave Glass Break Detector
I purchased two of those GoControl GB00Z Smart Glass Break Detector, I added to ISY under v5.0.5.
In the beginning I was only seeing the battery level at 0%.  I had to go out and back 1h30 later, I see a battery level of 0% and a Status of 0% as well.  Perhaps within next 24 hours the battery level will get populated.  I'm not sure what that Status = 0% mean and there's no "alarm on/off" status at all.
Z-Wave glass break sensors are rare, can we manage to add this one?
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ] ----------------------------------------------
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ] ZW016_1 uid=16 type=4.161.2 mid=335 tid=18242 pid=12336 model=0
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    -  x20  V1  BASIC
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    -  x9C  V1  SENSOR_ALARM
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    -  x80  V1  BATTERY
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    -  x82  V1  HAIL
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    -  x84  V2  WAKE_UP
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    -  x87  V0  INDICATOR
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    -  x85  V0  ASSOCIATION
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    -  x72  V0  MANUFACTURER_SPECIFIC
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    -  x86  V0  VERSION
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    -  x5A  V0  DEVICE_RESET_LOCALLY
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ] Node  16 - ZW 016 Alarm has the following neighbors
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    -          - Node   1 - [This ISY]
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    - Repeater - Node   3 - Repeater
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    - Repeater - Node   4 - ZW 004 Dimmer Switch
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    - Repeater - Node   5 - ZW 005 Dimmer Switch
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    - Repeater - Node   6 - ZW 006 Dimmer Switch
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    - Repeater - Node   7 - ZW 007 On-Off Power Switch
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    - Repeater - Node   8 - ZW 008 On-Off Power Switch
Tue 10/04/2016 16:45:04 : [ZW-SHOW         ]    - Repeater - Node   9 - ZW 009 Siren
Tue 10/04/2016 16:45:19 : [ZW-SHOW         ] Node  16 - ZW 016 Alarm cannot retrieve association groups
Tue 10/04/2016 16:45:19 : [ZW-SHOW         ] ----------------------------------------------
Tue 10/04/2016 16:45:23 : [ZWAVE-WAKEUP  16] Awake with no pending work, putting back to sleep ZW016_1
Edited by belanger
If I try to Query that device, I get the following pop-up :
Could not open config file to read
  [/CONF/0038.CZW]
Subscriber didn't reply to event: 1
   [39]
Edited by belanger
Hi belanger,
We do support glass break sensors, but I not sure whats going on with yours.  My guess is the query failed because the device was not awake.  I don't know why its not reporting its status or battery level correctly though.
We'll have to look at why you are seeing a percentage for the status.
The battery % level populated later w/ a value of 2 , confirmed via the z-wave msg shown in the logs.  The only other available value is still "status 0%", aka there's still no "on / off" alarm status.
I noticed at times variable showing up only after the device sent a message.  For example, the "Alarm on/off" might show up in the UI once the alarm trips.  If this normal behaviour?  I was always under the impression that all values would show up from the moment the device joins.  Without that variable, how can somehow program in advance a condition using any variables exposed by the device?
Let me know if you need anything else from me to troubleshot the device issue.
Pierre
Edited by belanger
When a device joins the network we query it, but in some cases it doesn't respond.  When that happens, we don't have a status for us to report for that device.  I have to check for 'Alarm' though, I think it doesn't even show the box in the GUI if it doesn't have a value.
Can you run the following from a browser using the ISY Address of your glass break sensor node (its something like 'ZW016_xxxxxx').
http:///rest/zwave/node/
/def/get
There you go :
<nodeDefs>
  <nodedef id="UZW0026" nls="148">
  <sts>
    <st id="ST" editor="_51_0"/>
    <st id="BATLVL" editor="_51_0_R_0_100"/>
    <st id="ERR" editor="ZW_ERR" hide="T"/>
  </sts>
  <cmds>
    <sends/>
      <accepts>
        <cmd id="QUERY"/>
        <cmd id="WAKEOPTS">
        <p id="INTERVAL" editor="ZW_WAKE_INTERVAL"/>
        </cmd>
      </accepts>
  </cmds>
  <links>
    <ctl/>
    <rsp>
      <link linkdef="ASSOC"/>
      <link linkdef="ASSOC_CMD"/>
    </rsp>
  </links>
  </nodedef>
</nodeDefs>
