AT&T to end email-to-text ×
2475DA1 Cannot determine insteon engine
Banichi
Okay, I admit I am not smart enough to handle this but, here is what I know:
1. I tried dozens of times pressing the link button for 5 seconds. First the button then start linking - no success in ISY; Then started linking first then the button for 5 sec. - no success in ISY. Then button for 5 sec first then add device with address keyed and discover device type - no success in ISY; next, the add device with address keyed and then the button - no success in ISY; next the button first and add device with address keyed and device = 2843-222 - no success in ISY; next add device with address keyed and device = 2843-222 and then the button for 5 sec - no success in ISY;
2. Meanwhile, all this time the device was properly triggering the relay for the lights;
3. Every time I did this using all the different methods described above, I would see either:
a) not find the device at all; or
B) start to add the device and then report "Cannot determine Insteon Engine"
4. After Michel suggested the second push of the button I tried the following:
a) Start the admin console
B) Start the add device using the address and the device type set to Open/Close sensor 2843-222
c) Push the 2843-222 button for 5 sec - Green light blinking
d) Release the button
e) Push the 2843-22 button once - down then up - the pattern of green light blinking has changed
e) Return to and view admin console; device is being added successfully on the first try
It has been perfect ever since operating the relay and in the ISY.
I do not know how or why this worked but it did.
It happened exactly the same to me. Thanks to this post could solve the issue.
FYI - apparently the Leak Sensor needs this extra tap too.  http://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Linking_a_Leak_Sensor
However, Insteon's Leak Sensor Manual doesn't mention this.  http://cache.insteon.com/documentation/2852-x22-en.pdf
Carl
Yes, I installed two leak sensors in the last week and both could not be found by putting them in Link Mode. As soon as I added the second button tap to change the blink frequency, my ISY found them instantly!!!!
I have found that lots of the packaged instructions are not accurate.
      37.7k
      376.8k
