Missing Desktop Icon after updating to 4.5.4
I just updated from 4.5.1 to 4.5.4.  I next cleared the Java cache and went to http://isy.universal-devices.com/994i/4.5.4/admin.jnlp to download the newest UI.  This does work and shows both the firmware and UI are 4.5.4.  Unfortunately I don't get an icon for the desktop, so each time I have to go to the above mentioned address.
Thank you for your help,
Ron
Check Java. Is "Keep temporary file on my computer," selected?
If you don't like keeping temporary Java files you can download admin.jnlp and place it on your desktop.
I have found that while you do lose some benefits of keeping temporary files, it solved a lot of other issues.
B.R.I.A.D.A.
Best regards,
Gary Funk
I pull down the admin.jnlp, rename it to admin-4.5.4.jnlp (or whatever version we are at) and put it in a directory with all the other versions. Then I can run whatever version I need to, without worrying about the cache by double-clicking on the desired version. It's been very beneficial while using multiple ISYs at different firmware levels.
Edited by MWareman
