Program to control SWL with IR.
Can anyone show me an example of the best way to control a switch linc dimmer with using only two different IR codes learned into the ISY? I want to be able to turn the light on and brighten with one code and then turn it off and dim with the other. The difference, I think, would be that the buttons will be "held" to brighten / dim and "pressed" for on /off. I am not sure if how to use the fade up, fade down, fade stop commands here. I can't seem to get it to brighten when it is off. I have to turn it on then brighten
MV
Hey Michael -
I do that using 4 programs. The following example uses a scene, but a signle device would be the same.
THEATER ON
       IR '1' is Pressed
       Set Scene 'TheaterMain' On
THEATER OFF
       IR '2' is Pressed
       Set Scene 'TheaterMain' Off
THEATER BRIGHT
       IR '1' is Held
   And IR '1' is not Released
       Set Scene 'TheaterMain' Fade Up
       Set Scene 'TheaterMain' Fade Stop
THEATER DIM
       IR '2' is Held
   And IR '2' is not Released
       Set Scene 'TheaterMain' Fade Down
Now that I think of it, I could probably combine the first 2 programs like this:
THEATER ON/OFF
       IR '1' is Pressed
 And IR '2' is not Pressed
I haven't tested this...
Thanks Mike,
I tried the combonation and it worked great.
Thanks for your help.
Mike B,
First, thanks for your help.
If I followed the instructions you gave me and it work great for one dimmer.What is the best way to dim more than one dimmer using an IR code. When I added multipe lights to your "Theatre Dim / Bright Program" the lights do not brighten / Dim at the same time so the first dimmer in the program are compltely on or off before the last one starts dimming / brightening. Is there a way to hold an IR button and have 2 or more brighten / Dim at the same time and rate?
Mike B,
Make a new scene with the all lights you want to control.
If they are at different levels the softest ones will turn off first, but they will all fade at the same rate.
Rand
Definitely like Rand said, create a scene and add the lights you want to control to that scene. Then, in your IR programs, control the single scene (and not the individual devices).
Good luck!
