Comparing eKeypad and MobiLinc
eKeypad Pro supports direct access to ISY and Elk and has blueprint layout mode. MLHD accesses the Elk via the ISY add on module and has cloud based access. Both can be configured to access the ISY/Elk remotely via port forwarding and setting up DyDNS in your router. I have both. It all depends on your GUI preference.
My experience is that eKeypad is faster to respond, supports my Elk better via direct connection, and is updated more often. On the other hand, the UI for ISY devices looks outdated and is missing support for some critical items (I can't figure out how to control an IOLinc, for instance, and program/variable support is limited or non-existent). For speed, reliability, and Elk-specific stuff, eKeypad Pro is my go to app. If I need to do something more complex with ISY programs and variables, I use Mobilinc.
Edited by rccoleman
