Concerned! Lots of odd devices added in the alexa app
I noticed that oddly when I tell something to turn on, it's functioning like I said off.  If I say 100% it does turn on however.  My first thought was to log into the alexa app.  In addition to my devices, I noticed the following:
cin av (Offline)
Cinema avant (device)
Forget
locker (Offline)
Locker (device)
Forget
test (Offline)
test (device)
Forget
second test (Offline)
toggle hallway (program)
Forget
vest (Offline)
Vestibule (device)
Forget
lavabo (Offline)
CuisineLavabo (device)
Forget
sdb (Offline)
Salle de bain (device)
Forget
douche (Offline)
Douche (device)
Forget
fireplace (Offline)
Vestibule.Scn (scene)
Forget
hhhh (Offline)
Cuisine (device)
Forget
balcon (Offline)
Balcon (device)
Forget
sfam (Offline)
Salle familiale (device)
Forget
neon (Offline)
Garage Neon (device)
Forget
first floor (Offline)
Thermostat RC (thermostat)
Forget
upper hallway light (Offline)
Palier etage (device)
Forget
hallway (Offline)
Forget
kitchen (Offline)
Forget
ilot (Offline)
CuisineIlot (device)
Forget
garage lights (Offline)
Garage Light (device)
Forget
sad (Offline)
Luminaire SAD (device)
Forget
entree (Offline)
Entree (device)
Forget
cin arr (Offline)
Cinema arriere (device)
Forget
garage door (Offline)
Chambre maitre (device)
Forget
living room (Offline)
Thermostat Etage (thermostat)
Forget
second floor (Offline)
Forget
deck (Offline)
Deck (device)
Forget
I issued a discover devices command.  It only found my devices.  The other devices remained, albeit "offline."  I manually deleted them to see if they come back.  Any ideas how this could happen?  Very concerned and not sure what to do or what to check to get to the bottom of this.
That was a test that UDI did a short while ago. Forgetting and discovering is the fix, as you've found. Not to worry B)
BTW, if you scroll down, then you can forget all devices at once.
Edited by stusviews
I, too have noticed a bunch of oddly named devices in my lineup. I also deleted them and they have not yet returned. I had thought at first that they were misinterpretations of verbal commands, but upon further consideration, I realized that shouldn't have created additional devices. I, too would be interested in knowing where they came from and how to prevent them from recurring.
Ok, thanks.  I feel better now.  As to my first issue, I know this is the wrong forum but since Ive got your attention, I noticed that a lot of my devices are suddenly show "On Level (Applied Locally)" set to 0.  I changed them to 100 but it only retained that setting for a few.  The others reverted to 0.  Does this sound like it could be a failing PLM?  Should I make this it's own thread?
Yes, a new thread will elicit more responses.
