Aeotec Nano Dimmer
Nano Dimmer dramatically improves the lighting in your home. Our 3rd generation of invisible lighting controller outperforms all that has come before it. Dimming is smoother. Compatibility is broader. Lighting is faster and more responsive. Automation and intelligence have never been more powerful. And it comes in such a small size, that you’ll be amazed at just how much functionality we were able to craft inside.
Perfect lighting is a part of every truly smart home. Lighting that is responsive. That is always the right brightness. That is always on when you need it, and off when you don’t. But perfect lighting has never been easy.
Instead, perfect lighting has been too complicated to achieve. In the past, to automate your lights with Z-Wave you’ve had to worry about the type of wiring you have, whether your lighting is trailing or leading edge, and whether you’re using TRIACs or thyristors. Far too complicated. Get any of those wrong and your connected lighting would quickly become a connected headache...
http://aeotec.com/z-wave-light-dimmer-switch
Fantastic concept, but really has anyone actually managed to stuff one of these type things into a wall box behind the switch? I've barely managed to get the wiring stuffed back into the box after adding a Z-Wave switch. I sometimes have up to 3 ends of romex to fight with back there.
