Silly RemoteLinc Question
I Have been replacing an extensive X10 system with Insteon and having pretty good luck so far. I am trying to add some RemoteLincs and have run into a snag. I understand that you need to input the address to link to ISY but I can't find an address on either RemoteLinc. Is there a standard address or is there some way to discover the address? Thanks
Hello Ken,
The RemoteLinc's address label should be found inside the battery compartment (you may need to remove one or more batteries).
