Motion OFF only on conditions?
Help!
I'm having trouble figuring out the right programming for this.
I want a motion to turn OFF lights only. Easy enough: not linked to the light, only to the ISY; use a program to trigger the OFF, and ignore the ON. This way I can control via ambient light levels or time of day or whatever whether it will go on or not.
The challenge is that I want a "warning" before I turn it off based on the timer. I'm a bit stuck on how to do that AND have the warning work by calling OFF the "turn off the light" function if there is more motion.
How about something like this:
       Control 'Motion Sensor' is Off
   And Control 'Motion Sensor' is not On
       Wait 30 seconds
       Set Scene 'Lights' Off
       No Actions
I haven't tested this, but I believe this would turn the lights OFF 30 seconds after receiving the Motion Sensor's OFF command UNLESS more motion is detected during that 30 seconds.
Yes, that works Mike. Here I have added a flash for a warning.
       Control 'Motion Sensor' is switched Off
   And Control 'Motion Sensor' is not switched On
       Wait 30 seconds
       Set Scene 'Lights' Fast On
       Set Scene 'Lights' On
       Wait 30 seconds
       No Actions
Rand
