February 22, 20179 yr Hi, I'm relatively new to ISY and miss my iPhone client when I am remote. I subscribe to the UD Portal Service to enable Alexa access already. Can anyone recommend which mobile client to get? I have isy994i zw. Use Alexa for voice. Have mostly insteon install with some zwave. And I have the UD portal subscription. Which is the right tool to get? Mobilink seems popular - but even then there are multiple versions. Thanks! Chicago Sent from my iPhone using Tapatalk
February 22, 20179 yr You can try MobiLinc Lite for free to see if you like it. It has a # devices limitation. If you like it then you can upgrade it to the full version. Warning, if you are running the 5.X Alpha software on your ISY, some things won't work correctly.
February 23, 20179 yr Mobilinc is the best. It's just pricey. If you don't mind the price get it. I wrote xcontrol which isn't perfect but what I use everyday. I like the quickness of it and it's less expensive. There are a couple others but I haven't used them for a long time.
February 23, 20179 yr eKeypad is quite nice too, especially if you have other devices (Elk, IP Cams, etc). Worth checking out Sent from my SM-N910W8 using Tapatalk
February 23, 20179 yr Author Any comparison between eKeypad and mobilink. Sent from my iPhone using Tapatalk I'm really confused by the different versions of mobilink. How do I know what is right? Sent from my iPhone using Tapatalk
February 23, 20179 yr Have you looked here? http://mobilinc.com/apps/version/ Sent from my iPhone using Tapatalk
March 9, 20179 yr if you do go with MobiLinc, don't get the Orchestrated version unless you REALLY want resource management, because it is just wasted screen space if you don't need it.
March 9, 20179 yr Author Thanks! I have bought mobilink. I am already using the UD portal service. It seems like many of the more interesting mobilink capabilities like geofencing and remote access do not work over the UD portal which is frustrating. Sent from my iPhone using Tapatalk
March 9, 20179 yr Author Is there a way to have a custom list of devices or scenes to rapidly assess status? I do like how it supports lock and sensor status. Sent from my iPhone using Tapatalk
March 9, 20179 yr Thanks! I have bought mobilink. I am already using the UD portal service. It seems like many of the more interesting mobilink capabilities like geofencing and remote access do not work over the UD portal which is frustrating. Sent from my iPhone using Tapatalk Remote access works fine against the ISY Portal. For geofencing, look to the (free) Locative app. Currently, you can report location events via an IFTTT URL on the portal, but soon there will be full multi device, multi location functionality...
March 10, 20179 yr Is there a way to have a custom list of devices or scenes to rapidly assess status? I do like how it supports lock and sensor status. Sent from my iPhone using Tapatalk Yes, add them to your dashboard. Can include scenes devices and/or programs. You can then have the app automatically open to the dashboard, or a different screen if you want. Sent from my iPhone using Tapatalk Edited March 10, 20179 yr by TrojanHorse
